Introduction: The Making of a Beast: Part Two, the BiQuad Antenna
So now that basics are done on the WRT54G; now it is time to create the antenna I want to use. I have a small line of site path though some trees, to the area I want to broadcast to. So I wanted to use a Bi-quad with a parabolic reflector. I acquired all the parts for free, out of metal dumpster, and other scrap sources.
This instrucables was going to also include some more WRT mods; however, while de-soldering the RAM chip I damage a part of the board, so I am waiting on parts. So now there will be a Part Three :)
This will only discuss the making of the antenna. One could use any antenna element of choice; cantenna, dipole, or a bi-quad. This instructable is more about getting the juices flowing, to inspire some one to create better. And part three will be about how it all comes together.
The Prequel
Step 1: The Parts.
For the constuction of a Bi-Quad, the following parts are needed:
# A small section of 3/4 (or smaller) copper pipe, about 8".
# A piece of square, flat, copper, if using a parabolic dish the dimesions are 110x110mm, without 123x123mm is best. Copper clad PCB board works, I chose just a sheet of copper I found. You can use anything coductive, I use copper because the ease of workability, and low loss; however, you can use any metal for any part of the project.
#Coax, a LMR-195 if < 5' to the transceiver, LMR-400 if > 5', RG-58 will work if the section is short.
That's it.
If making a parabolic dish, one will need a dish :) Recycled one if possible. There is a lot of science about which size dish to use for 2.4GHz. Personally, this is about a cheap hack job, and I can get a lot more coverage with a old TV dish (direct tv style).
Skills & Tools needed:
# Soldering skills is a must, I used a propane torch for most of this project. A high watt soldering iron can, and has, worked.
# Hack saw, file, tin snips, wire strippers, a crescent wrench, flashlight.
# Ingenuity; each person that tries to match this will run into their own problems, wants, desires; we are here to help; yet, a level of McGyver like skills is a plus. I made this using no money, I could improve greatly on it If I choose. Make it your own.
And last but not least, educate ourselves :) I put some great links through the steps. If you are expert or novice, it helps knowing a little.
http://www.trevormarshall.com/biquad.htm
http://en.wikipedia.org/wiki/Parabolic_antenna
http://en.wikipedia.org/wiki/Antenna_(radio)
Step 2: Affixing the Reflector.
First thing we want to do is, make a square. If making side flaps, make it 30mm longer on one side, so 123x153mm or 110x140mm. I did not do this, it would impact a longer range signal. I made my flaps only 10mm
Once square, draw line corner to corner (of the square) to determine center. Find the out diameter of the pipe you are using, some of you might solder in a bulk head jack instead of pipe. Either or, drill a hole to fit.
Clean up any burrs and apply flux.
Next clean your pipe :) Polish until shiny, then flux and slip it through the hole.
To solder using a torch: Capillary action is used to make a good joint. If you have never soldered with torch; How to Sweat (solder). It is best to have the pipe in a vice and the sheet flat on the jaws of the vice. There will be warping, but it is another reason I like copper, it is easily taken care of later.
Heat up the sheet, as soon as it is hot enough, pull the flame back and lay in the solder, it should flow right into the joint, via capillary action :) Let it sit for a while, it is going to be hot. If using a soldering iron, take your time you will get it eventually, a 60w or 120w might do the trick. I would recommend learning to sweat solder. If using a copper clad board maybe not. A warning, each type of metal is different, do your research before you solder on it. I do not want some one taking a torch to a piece of magnesium. Another reason to use copper. :)
Step 3: Finish Up on the Reflector
If we have not cut to size, now is a good time, mark and use straight tin snips to make your cut. Another method is a sharp chisel and a hammer, on a wood surface.
After it is the size you want, making it straight is as easy as a hammer and a block of wood. I use an anvil as a backing, but anything smooth and tough will do. Give some good whacks and the copper will look as good as new.
Now I will cut the excess of pipe. The element needs to be between 15-17mm from the reflector. This will make for the lowest SWR, which is important. Since most of us do not have SWR meters for 2.4GHz, we can only take information from other and do our best.
(I have thought of ways to make this part adjustable, and would love to see some one do it. A hollow piece of threaded stock would work great. The SWRs could be tuned, then.)
I cut the back pipe enough to mount on my dish, how much to leave is up to the builder. After that, file down 1/2the diameter of the pipe, down about 3mm. So now one side of the pipe should be 15mm and the other 12mm. That is it for the reflector; the bends are optional, but they cut back on rear and side lobe radiation and are recommend when using a dish.
Step 4: Mounting on the Dish.
My dish did not come with the LNB, and I am kind of glad it do not. What one wants is a way to adjust x, y, and z axis and the polarization. I used a piece of power strut (useful stuff, search superstrut), and two pieces of scrap metal, a piece of PVC and a hose clamp. The bolt on the strut, lets me turn the x and forward and back on the z. The bend in the metal can allow me to move on the y.
This step is really up to the builder, I am just giving a basic idea how it can be done. It could be a lot more functional then this. and could even be servo driven.
Step 5: Tuning
Since I painted it white, it is reflective. If you don't want it white, cover it in tin foil. Or use algebra to figure out the right spot, search here. If you are lucky, the dish you will be using will have a LNB and you can go from there.
I used a flash light pointed at the angle I wanted. Then attached a piece of paper on the reflector and tried to get it dead on. It gave me about a 2" circle of light to work with. Now think there is a lot going on here, not only is this dish designed for a different use, but also a different antenna. LNB are mostly cantenna in design, so I brought the bi-quad back a bit farther.
Step 6: The Element.
Be patient, cut a piece of wire, I used a 14g solid copper which is 1.6mm. In researching this, I found size matters ;) 1.2mm is preferable. The thicker the wire the larger the bandwidth of the antenna. First straighten then cut it exactly 244mm. Measure and mark it at 122mm, make a 90 degree bend. From the center of the wire measure 30.5-.75mm mark and bend. Do this to each side until you get what is pictured. Two quad elements. Each length is a 1/4 wave of 2.4GHz. It a good thing to understand this Hertz thing so try here.
As soon as the perfect element is shaped solder the open ends on the high part of the pipe on the reflector. Measure, then measure again. Go around the entire outside edge of the element making sure it is off the reflector 15-17mm. Mine was 15.5mm all around after a couple tweaks.
Slip in your coax and solder the core to the center and the shielding to the inside of the pipe.
Done deal.
Step 7: Finish Up.
I coated everything copper with electrical anti-corrosion spray, then painted with light coat of not conductive paint. I am hoping it does not mess with the signal much. I do not think it will. I have made antennas for years and painted a bunch of them and never lost much db off the top. So any advice in that department, I would gladly accept. :) I made a sticker to :)
Next are some lighting mods, and some more work on the router and setup. Till part three, Thanx
20 Comments
7 years ago on Introduction
Nice tutorial, I have a couple of questions
What is the range of this antenna?
Do I need these antennas at both ends for long distance WiFi.?
What if we use a similar biquad as the transmitter and a laptop or smartphone as the receiver.
10 years ago on Introduction
Good info. I had a question though. I made one of these using aluminum for the reflector and instructions here and at http://www.engadget.com/2005/11/15/how-to-build-a-wifi-biquad-dish-antenna/ .
I haven't finished soldering everything in place, I was going to test it first. Although I can connect to the router I cannot see any networks that my computer doesn't already see. How am I suppose to connect the biquad to the router?
I first used a Canyon cnp-wf514n3 connecting the leads from the biquad to one of the antenna that I removed.
Next I tried my Belkin n600 and tried to connect to one of the 2.4gHz antenna.
Am I suppose to connect to both antennas, or use a special router. Thanks.
I used only one antenna, in DD-WRT, it has the option to choose (on most routers) which antenna to TX/RX with.
9 years ago
you should have not painted your dish it has a reflective paint on it already an if u paint over it it weakens the signal i use to work for direct tv an i had a few people paint there dish to match there house an over time it will weather off depending on exposure
Absolutely correct!! It put this project to a screaming halt. In the next part of the project I was going to wire the status lights to flash upon the dish (reason I painted it white); however, I started running into communication problems and reverted back to a old Wild Blue dish, without paint. My performance improved greatly.
12 years ago on Step 7
Also, from my research, the shielding on the coax should be soldered to the rear of the copper pipe if I am understanding this correctly. Just a couple thoughts. Great instructable though... one of the few detailed ones that do not require and "modification" to cookware :)
Reply 12 years ago on Step 7
No, it would create a drastic affect on the preformance if the shieling did not follow the feed all the way to the element. For instance one like this could have some problems http://www.lincomatic.com/wireless/biquadfeed.jpg
A great resource is: http://martybugs.net/wireless/biquad/
Thanks for the links. Very useful.
What I am not following is as follows: The "element"is grounded to itself in a way. you see how the bottom angle touches the copper pipe? I don't think this is how it should be. Not to sound like I know what I am talking about, because I am only going off of what I have seen on other biquad style antennas. If I do get a chance to make one of these I will test the difference, But I do expect there to be a difference.
Your correct it does in fact ground itself, creating a sharp stop in the driving voltage. This is noteable call impedence transformation, when thinking of a quad antenna, think of it like a folded dipole streched out. The short out increase the feed point impedence to balance the bi-quad to the coax. One could go far enough to find exaclty where it need to be, or even create a matching network, but that would be silly since it works darn well as designed. Thanks for your comments, good luck on the build.
12 years ago on Introduction
Good instructable! I have a question (two, really), for you or maybe another reader of this comment. I have DirecTV, and the parabolic antenna it is a little one, approx. 20-25 inches. Can I enlarge it to enhance the reception? In the rainy days, when one want to see TV, it fails... I think that adding a 5 inches width of wire mesh ring around the parable, it will improve. Will there be any legal impediment?
Reply 12 years ago on Introduction
You want to make the dish bigger, is that the question? Do you own the equipment or leasing it? I would check for LNB drift first before taking on any modifications. I live in WA, and we have lots a rain. Only time I have signifcant signal loss with my satelite TV or Internet is when snow is covering it. I would make sure everything is aligned, grounded good, and no corrosion on any connections. Check for signal strength, and LNB drift. If all pans out, I still would not mod the dish. Socially engineer DirecTV to make a change in your favor, a better dish, or a free service call, maybe.
Thanks for the response. I live in Argentina, here the reception problems on DirecTV are regular at rainy days, even if it is not raining in the town where the antenna is. Surely this is due to the low altitude of the satellites above the horizon, something evident when observing the parables, which point to very low altitude. I suppose that since this country is a relatively marginal concession area, the company does not show much enthusiasm to improve the conditions. I have not access to the LNB, I have not technical knowledge about that things.
If you live in Argentina why are watching TV, I would be fishing :) If were to add five inches onto the parabolic, the LNB would have to be slid farther back to capture the added signal. This would take increased modification to the dish, and tools to test signal. I would look into getting a FTA (free-to-air) setup.
Thanks for all. Do not think that in Argentina are not contaminated waterways, as in many parts of the world. To go fishing I would have to make many km, although I have the Rio de la Plata 10 Km away from my house. In TV, I look almost exclusively documentary films (NatGeo, THC, Discovery, Animal Planet, Bio and others) and news.
For Step 2 - 3, I'm thinking that if you cut the center hole radially [X or X and +(read 4 or 8 radial cuts)] instead of drilling, you might be able to carefully fold the metal outward to create a shoulder onto which you could place a screw-type hose clamp for adjustment purposes. ~/Lee
Great idea!! Creating the shoulders could allow for several other things to be soldered on. Soldering on a tube with set screw, in which another tube slide through could work. Thanx
wow very professional, i love the sticker to!
yeah it does look like somthing some big company would sell... sept the cat would be a DELL or somthing.. lol
Very nice. I've got an old dss myself and was going to put a USB wifi in the focal just to see whats in the neighborhood.
