Introduction: The Mysterious Ticking Noise - an Easy Arduino Prank
This project uses a relay to make a small clicking noise to confuse those in the area. When the electromagnet in a relay turns on and off, a small clicking noise is produced. If many clicks are emitted randomly, it wil likely confuse people in the area.
Note - This project is not to be used as a fake bomb or a bomb scare. Please be smart about how and where you use this. I am not responsible for any problems caused by this device.
Step 1: Gather the Materials
You will need -
- One Arduino device, such as the Nano or the Uno
- One USB cord to connect to the Arduino device
- A power supply for the Arduino device, such as a phone charging stick
- A relay module (I used a one channel relay module, as it is small and can be easily hidden)
- 4 male to female breadboard jumper wires
Step 2: The Circut and Code
Circuit Wiring -
Arduino pin D7 ---> Relay IN1 pin
Arduino GND pin ---> Relay GND pin
Arduino 5v pin ---> Relay VCC pin
Arduino pin D6 ---> Relay pin SGND
NOTE - You may want to cover up the on-board LED on the Arduino device and the relay, or the light might be seen and your great prank will be foiled.
ANOTHER NOTE - Leave the jumper on the relay module. This tells it that you are using the power from the Arduino board, not a seperate source.
The Code -
The code has two parts - the delay at the beginning, then the clicks. My code continues clicking randomly until the Arduino device runs out of power, or gets unplugged.
<p>/*<br> * Code created by AW on 4/14/2020
* Last edited by AW on 4/14/2020
* This program causes a specific pin, (determined by the variable changeME) to flash on and off at a random number of seconds.
* The random maximum number is determined by the variable randoMAX.
* The random minimum number is determined by the variable randoMIN.
* This code was meant to click a relay on/off randomly as a prank to confuse people.
int changeME = 7;//set variable to the pin number or name
int randoMAX = 3000;
int randoMIN = 500;
int waitTime = random(randoMIN,randoMAX);
void setup() {
pinMode(changeME,OUTPUT);
pinMode(6,OUTPUT);//pin 6 is needed to control SGND
digitalWrite(6,HIGH);
delay(7200000);
}</p><p>void loop() {
digitalWrite(changeME,HIGH);//turn on the pin
delay(waitTime);
digitalWrite(changeME,LOW);//turn off the pin
delay(waitTime);
}</p>Step 3: Plant Your Prank
After turning on the power source, plug in the Arduino and leave in an unknown location.
Step 4: Results
Watch or listen as everyone in the room tries to find the location of the device.
More ideas -
This device was on a timer, but it could also be controlled by a remote, or a sensor.
