Introduction: The (Not So) Ultimate Knex Marble Machine Element Guide
If you read the title and clicked on this instructable, you probably can't afford Knex balls or are just curious. Each step will also include a list of pros and cons. So, today I present to you, The (Not So) Ultimate Knex Marble Machine Element Guide!
The parts for each step of this instructable will be listed there. You will need Knex and marbles.
Step 1: Simple Path
The most basic path for a marble machine. Each segment needs two yellow connectors, two blue spacers, and a white rod. (I recommend using a blue rod for segments that will connect to something.) To connect two segments, you need two green rods.
Pros:
-Minimal pieces
-Simple to build
Cons:
-Breaks easily when twisted
-Can't turn
Step 2: Finish!
That's It! If you have any questions or suggestions, you can comment them if you like!
