Introduction: The Office Jello Prank Tutorial
A tutorial on how to make the Jello Prank from the office!
Step 1: Materials
Firstly, you need to obtain all the materials listed to make this jello prank. The materials are listed below:
- 1 Large Jello pack (6-ounces) or 2 small jello packs (3 ounces each)
- Source to measure liters of water
- Kettle/Source of boiling water Bowl
- Spoon (For mixing)
- Refrigerator
- An item from a friend/family that you would like to put in the jello
Step 2: Preparation
Boil two cups of water using a kettle or another source of boiling water, and open the large 6-ounce pack of jello powder (or two 3-ounce packs ) & insert it into the bowl (bowl should be big enough to hold 5 cups of water)
Step 3: Mixing
Pour the two cups of hot water into the bowl with the jello powder and mix until there are no more powdery granules (2-3min). After doing so pour two cups of cold water and mix for another 2-3 minutes.
Step 4: Adding the Object
Add a waterproof belonging of a family member/friend into the bowl with the jello mix. It's better if the belonging is something that they use constantly! (If you just want the jello as a dessert you don't need to do this)
Step 5: Finalizing
Lastly, wrap the bowl with plastic wrap, insert it into your refrigerator, and keep it there overnight. (It might not be 100% jello by the next day. To tell that the jello is ready, place your finger gently on the jello and when you remove your finger from it there should be none sticking to your finger).
Step 6: The Prank!
When the jello is ready, flip it over a plate, put the jello back into where the item came from, then watch your friend/family member react to their belonging being in jello! Film it, it'll last longer!
