Introduction: The Organizer
We are as students, we always need something that organize our staff. And, that thing would be better if we create by ourselves because we know what we need. Here, in this project you will be able to create your organizer with simple materials and less cost. All these materials that I use in this project you can find around in your home. It is also very flexible task because there are alternative materials you can use. So, let’s START
Step 1: Collect the Material.
Collect
these materials that you can find in your home:
1.One Pasta container.
2. two Clorox containers.
3. glue.
4.Scissors.
5. cork-board.
6. wrapping paper.
Step 2: Cutting the Containers.
◦ Cut the Pasta containers into a 5 inch strip.
◦Cut the clorox containers down the middle to create two 8 inch cups , so cut from the middle to 8 inch.
Step 3: Wrap the Tubes
Glue the paper into the tube.
In these tubes and wrap them to become a cup.
Step 4: Glue the Cups.
Glue the cups on cork-board.
“note, you should wait until the glue gets dry. It may take from one to two hours”
Step 5: Cut.
Cut the paper to be cloud shape.
Note, I used Powerpoint to make this paper.
Step 6: Glue.
•Glue the cloud shape.
•Put one on the left side, and the other one on the right side.
Step 7: Time to Work!
It’s very simple project, and all things in your home could work with this project. Yes, there is a lot of organizer to buy, but when you do it with yourself, it’s will be cheaper and you could spend your time in good way.
