Introduction: The Perfect Gift: RAW Cookie in a Mini-Box
Necessities to make a Mini-Box
• Printer
• Card Stock (110 lb. white or color works best)
• Cutting Surface (i.e. IKEA thin plastic cutting board)
• X-Acto Knife
• Ruler
• Letter Opener / Boning Tool
• Colored Pencils / Pens
• Rubber Cement - Glue
• Tissue
• Ribbon
• Printer
• X-Acto Knife
• Ruler
• Tissue
• Ribbon
Step 1: Print Out the Mini-Box Pattern
Download the PDF (below) and print it on your preferred type of paper.
I tried printing the mini-box patter on a couple of different types of paper but I found that 110 lb. card stock works best. I used 110 lb., 8 1/2" x 11" White Card Stock paper from Staples. I colored the box by hand (which was why I used white card stock) but if you want a solid colored box, you could just print the pattern on a solid colored card stock.
Step 2:
Using an X-Acto knife, ruler, and cutting board, cut out the mini-box pattern that you printed out in the previous step.
Step 3: Fold the Mini-Box Along the Dotted Lines
Using a ruler and a boning tool or letter opener, fold along the dotted lines.
Step 4: (Optional) Decorate the Mini-Box
Using whatever decorative medium you like (pencils, pens, paint, stickers, chalk, pastels, etc.), decorate your Mini-Box.
Step 5: Fold the Mini-Box
Fold the sides of the box up and wrap the bottoms around each other - PURPLE over and then under RED.
Once the RED and PURPLE bottoms are in place, wrap the 'secure bottom piece' around and tuck it into the bottom (the WHITE piece under the RED flap).
Step 6: Glue the Side
After you have secured the bottom, glue the front of the box together at the opening.
Step 7: (Optional) Tissue and Bow
Place tissue in the bottom of your *almost* finished box. Using a needle or the tip of your X-Acto Knife, make two small holes under the lid of your box - at the hole marks. Thread a small ribbon through the holes and tie a bow on the lid of your box. If you want to use a larger ribbon, make larger holes.
Step 8: (Optional) Personalize Your Mini-Box
Add a "To," "From," and/or personal message to the sides of the box.
Step 9: Your Mini-Box Is Complete
Your Mini-Box is ready to be filled with the RAW cookies you've made and given to your lucky recipient!
Step 10: A Great Book on Box Making
Although we didn't use this book directly, it's a great source for box making inspiration. ::LINK:: on Amazon.
Step 11: NOW, for the Walnuts for Cinnamon RAW Cookies!
You will need:
A Blender.
A measuring spoon.
A measuring cup.
2 tblsp sunflower seeds.
1 cup pitted Medjool dates.
3/4 cup walnuts.
1 cup mixed dried berries and nuts (i used cranberries, raisins, cashews and almonds).
1 tsp cinnamon.
Pinch sea salt (to taste).
A Blender.
A measuring spoon.
A measuring cup.
3/4 cup walnuts.
1 tsp cinnamon.
Step 12: Prepare Ingredients for Blending!
Measure out ingredients and put them in individual bowls, this makes it way easier to concentrate on whats going on in the blender in the next stages!
Step 13:
Put the Walnuts, mixed nuts and berries, cinnamon and salt in the blender.
Pulse into nice chunks.
Be careful to not over blend, or the nuts with start to form a butter.
Step 14: Dates and Sunflower Seed!
Add the sunflower seeds and dates to the mix!
The dates will make the dough sticky, and difficult to blend.
Regularly stop the blender, and dislodge the mixture in the base with a spatula.
Step 15: Dough!
When you think all the ingredients have formed a sticky dough, remove the from the blender and place on a flat surface.
Step 16: Taking Shape!
Use a table spoon to scoop the dough into balls and then use the palm of your hand to press the balls into cookie shaped portions!
Step 17: Keep Them Safe!
These will keep for about a week in the fridge, but for well over a month in the freezer!
Put them in a tupperwere until you're ready to put them in your beautifully hand crafted gift box!
