The Pillars of Time - a Steampunk Nixie Clock
Intro: The Pillars of Time - a Steampunk Nixie Clock
The Pillars of Time- A Steampunk Nixie Clock and my 10th Instructable ;)
Made from pure Brass and Coppertubes.
STEP 1: Things We Need
Many Brass Parts and Ornaments from Candleholder and Lamps
14 ( 12 ) Same Brass Tulips from Candleholders
White Leds or another Colouer you like
Popplar Wood for the Case and Wood Colour. I used dark walnut
10 k PotiĀ“s
Bakelite Rotary Knob
Nixie Kit from PVElectronics here
6 Nixie Tubes IN-8. You must look on Ebay
IN-8 Nixie Socket here
Many thin Cables
Nitric Acid and Sulfur Liver for Colouring
Brass Gears from a Clock
Small Loudspeaker ( if you want ) instead of the Buzzer
Brass Chains and Chainwheels from a Cuckoo Clock.....
and other things which ye install yourself yet
Please note . I know that it's hard to get all these parts , and it should only be an incentive and inspiration to be at the same time to build your own Nixie Clock. A little imagination and you can build amazing Things :)
STEP 2: The Holders for the Nixie Tubes
In these three images you can see how I did the holder for the Nixie tubes .
I have done this 12 times . Sawing , filing and solder together.
Six as a shell and six as dividing . The shell is removed to possibly even to change a nixie .
In these pictures you can see the bottom part .
STEP 3: The Tops
24mm brass ring .
Drill two holes into it and then solder the Nixie Holder.
Take a 5mm brass screw and solder them to a gear . On the gear their solders then again a brass ring . The whole now serves as a locking screw .
Once a Nixie should fail you open the screw and pushes the top upward .
STEP 4: Aligning
Now you push the top part on the copper pipe and aligns it with the bottom part . They should fit together exactly .
After that you solder a small piece of a copper pipe with the inner diameter of the potentiometer .
STEP 5: Adjust the Nixie Base
Ttake the dremel or proxxon and a small grinding roll . Now grind the base around until it fits into your bracket .
Now plug the tube and solder the pins in the socket (pic4) .
STEP 6: The Kit
Now you solder the Nixie kit according to instructions together.
After that, patinate the brass parts . You can leave it shiny . As you wish. ;)
Make a base according to your notions .
Now you build just once all temporarily assembled . (pic 3 )
Now solder for all switches on the main board an extra switch . They must be operated from the outside , yes. (pic 4) One Switch is for external lighting of the copper pipes.
To the beautiful bright picture of nixie tubes not deface , I have omitted the lighting of the nixie tubes .
now you soldered to the base nixie thin cable with enough length to . The cable must be so long that they go through the dividing up of the board .(pic 5 )
The solid cable and the board ( pic 6 )
the soldered cable on the board as it is in the construction manual of the kit . ( pic 7 )
But before soldering the cable to the motherboard, testing please the connectors so that the nixie 5 displays on pin . 5 and 8 display on pin 8.......
STEP 7: Assembling and Final Result
Now you solder the pot in series with the leds for lighting columns . Glue the Potentiometer in the small copper pipe disposals . On the pot are still stuck chain gears . Install on the upper bracket also a chain gear.
Connects the two sprockets with a brass chain . Now the upper sprocket rotates with when you pressed the potentiometer . ( pic 1, 2, 3 )
The external switch now even dress up with some decorative ornaments . ( pic 4 )
I know it is not easy to follow my instructions and declarations . Also, I have problems with the translation , and possibly can not exactly explain everything that everyone understands it .
But I think the pictures speak for themselves and it can begin to develop as it was intended or made much .
Nevertheless, I hope that this instructable was a stimulus for you to create many new things.
But if you have to ask then asks .
Your Leander Lavendel
5 Comments
Roddy Scott 6 years ago
Originality is what sets these clocks apart from just building the kit and yours is very original.
I like the idea of controlling the LEDs with a potentiometer. The DINK kit is ideal for designing your own clock as I have used a few myself in different Nixie clocks.
Again, nice work!
prototype_mechanic 7 years ago
My greate respect for nixie builder
HowWoode 7 years ago
Very nice!
ThirdEarthDesign 7 years ago
Great Nixie Clock, thanks for sharing!
bricabracwizard 7 years ago
I love what you have done here, excellent work!
