Introduction: The Pixar
This is a studying lamp from pixar but, with robot legs. You can put the lamp in any position you want.
Step 1: Step: 1 Buy 3 CHC Screws M6*45
You need these screws to have the robot legs in place. And with these screws you can put the robot in any position you want.
Step 2: Step 2: Assemble the Robot
If you downloaded all the robot parts, you now have 9 parts of the robot.
First put the left and right legs in his body. and put the screws between the hols.
Step 3: Step 3: Assemble the Nek and Head.
If you did the last step correctly the legs are now attached just like the picture above. Now we are going to focus on his upper body, nek and head.
First put his upper back (The one with the hole in it) in to his body 1 like I did in the second picture. now you'll see that it has 2 legs, lower back and upper back.
Now we are going to put his nek in to place (the head-axis) put this part in the hole you see in his upper back. Be sure to have gap facing correctly. Not sure? check the third picture. If you've done that the last step is to put LightProjector-Mount in place just like I did in the fourth picture. Be sure you screw everything.
Step 4: Step 4: the Head
Now you'll see we have done everything but we still have 3 objects left. the head, the transparent face and the ring. put the parts in the order I show you in the first picture. The transparent face comes inside the head and the ring must come on the edge. Be sure to use glue for this or else it will fall apart.
Not Sure? check out the first picture. And check out the second picture for the compleet head.
This is the last step. Now you need to put everything in to place with glue. in the last step you put the lightProjector- mount in to place the head is going on there with glue.
Be sure to put pressure if you want to stick it together or else it won't be hardend.
If you've done every step correctly you now have a robot lamp.
