Introduction: The PolyPHONIC Kitchen
Our TEAM
Noah Pitts
Sara Montoro
Karl Landin
Alice Lee
University of California, Berkeley
CNM290/CS294-85
Critical Making: Materials, Protocols, and Culture
Our MISSION
The activities of the kitchen, once communal practices shared by members of a household, have become increasingly solitary in our fast-paced society. Busy schedules leave little time for family members or roommates to socialize while preparing meals, and kitchen interactions can become cold and uncomfortable. With the PolyPHONIC Kitchen, the sociality of the kitchen space is innovatively reclaimed. Sensors are set up on commonly used kitchen surfaces and, when triggered, play enjoyable music sequences that build on each other, creating a unique song. Opening a cupboard, the refrigerator, or turning on the stove becomes a social interaction, and the shared kitchen space becomes a place where members of a household may connect with each other without changing their routines.
Our HISTORY
The PolyPHONIC Kitchen was born out of our group’s discussion about kitchen silence. One member noted that cooking alone is often quiet and monotonous, and that an activity such as music might be needed to break the silence. Another member noted that in her own kitchen, an awkward silence was overcompensated for due to the presence of housemates who shared the kitchen but did not know each other well. The unfamiliarity between housemates seemed to volumize each sound that was made - cupboards slammed, dishes clashed, and cutting vegetables sounded like chopping down a tree.
We took photos of this “awkward kitchen” and decided to analyze what made sharing it with housemates such an uncomfortable space. Noting the positives of an antisocial kitchen, one group member observed that being uncomfortable with each other often means that roommates are more likely to clean up after themselves, do the dishes, and respect each other’s items. We then compared this experience to living with friends who we knew well, or perhaps knew prior to moving in. The unfriendly atmosphere of the awkward kitchen, we realized, was due to the lack of opportunities for members of the household to interact outside of the kitchen and discover things in common. The house does not have a living room or any other common spaces, and the people who live there are divided by age, area of study, and language.
With this data with we determined the four main qualities of the awkward kitchen - silence, language barriers, close quarters, and a lack of opportunities for social interactions outside of the kitchen - and searched for a solution to overcome them.
Step 1: Parts List
5x 10K Potentiometer (with knobs)
4x Magnetic Reed Switch
1x Motion Sensor (not used in this prototype, but we'll suggest how you can incorporate it)
Wire
A computer
Computer Speakers (optional)
Kitchen cabinets and stove range (for this prototype, we fabricated these)
Step 2: Setting Up Your Computer
Install the latest version of the Arduino IDE so you can program your arduino and have it communicate through the Serial Port.
Then you'll also need to download Processing. We recommend the 32-bit version if you're on Windows or Linux as the 64-bit version seemed to have trouble with the Minim library we used.
While these are downloading, set up your kitchen with the next step!
Step 3: Hooking Up the Kitchen
The AUTOCAD file (polyphonicKitchen.dwg) is attached below if you would like to laser cut a demo version (like the one shown in this instructable) of a stove and cabinet. This file could also be used to lay out dimensions and cut by hand.
To assemble the reed switches, secure the wired end onto the inside on the opening of the cabinet. You should glue/tape/screw this switch at a location where it and its wires will not be hampered with. The very top of your cabinet or a side would be a good place. The other, unwired half should be secured to the door at a place where it will align with the wired half. Make sure that the wires are long enough to reach wherever your Arduino will be placed.
To assemble the potentiometers, replace the knobs of your (preferably fake) stove with the knobs of the potentiometers. Secure them and then solder on appropriate wires to the three pins of the potentiometer. Again, make sure these wires are long enough to reach your Arduino.
Step 4: Hardware Setup
Every kitchen is somewhat different and therefore it is best to draw up a simple schematic of the kitchen that is intended to be used. There is potential to turn almost anything into some sort of input for the polyphonic kitchen. Cabinets, drawers, knobs, switches, anything really,,, Once a scheme is decided upon that is endemic to that kitchen you can use the arduino code as an initial boilerplate to bring in all of these inputs into processing which will do all of the audio playback. This prototype was presented in a classroom setting and therefore a model was used to simulate a kitchen interface. If you’re interested in recreating this model, you can follow these schematics more closely, otherwise some augmentation is expected.
Wire it all up. Make sure the pins are in the right places. If different pins are used or even different sensors, then the arduino code (in step 5) must be updated to reflect those changes. Once the arduino is programed it will need to remain connected to the computer through the serial port in order to communicate with processing.
Step 5: The Code: Arduino
We have hooked up 4 magnetic reed switches and 5 Potentiometers. If you added more/other sensors into your Arduino, you should incorporate them into this code by defining which pins represent which sensors and then outputting them via the Serial port at the end.
One last thing to note: the zip file contains an Arduino sketch placed within a folder. You will need this file hierarchy for Arduino to load the sketch properly. Please place the file within a folder of the same name.
Arduino Code:
Sara Montoro
Karl Landin
Alice Lee
Noah Pitts
CNM290/CS294-85
Leave us a comment if you have suggestions and other ideas!
//set digital pin (mag switch)
const int mag1Pin = 4;
const int mag2Pin = 5;
const int mag3Pin = 6;
const int mag4Pin = 7;
//set analog pin (cap sensor & pots)
const int capSensePin = A0;
const int pot1Pin = A1;
const int pot2Pin = A2;
const int pot3Pin = A3;
const int pot4Pin = A4;
const int pot5Pin = A5;
//set var (mag)
int mag1State, mag2State, mag3State, mag4State;
//set var (pot)
int capSense =0;
int pot1Val = 0;
int pot2Val = 0;
int pot3Val = 0;
int pot4Val = 0;
int pot5Val = 0;
void setup(){
//start serial connection
Serial.begin(9600);
//configure digital input and enable the internal pull-up resistor
pinMode(mag1Pin, INPUT_PULLUP);
pinMode(mag2Pin, INPUT_PULLUP);
pinMode(mag3Pin, INPUT_PULLUP);
pinMode(mag4Pin, INPUT_PULLUP);
void loop(){
//read the magnet value into a variable
mag1State = digitalRead(mag1Pin);
mag2State = digitalRead(mag2Pin);
mag3State = digitalRead(mag3Pin);
mag4State = digitalRead(mag4Pin);
//read and map the pot value into a variable
pot1Val = analogRead(pot1Pin);
pot2Val = analogRead(pot2Pin);
pot3Val = analogRead(pot3Pin);
pot4Val = analogRead(pot4Pin);
pot5Val = analogRead(pot5Pin);
//send to serial: capSense
Serial.print(capSense);
Serial.print(',');
//send to serial: pot1
Serial.print(pot1Val);
Serial.print(',');
//send to serial: pot2
Serial.print(pot2Val);
Serial.print(',');
//send to serial: pot4
Serial.print(pot4Val);
Serial.print(',');
//send to serial: pot5
Serial.print(pot5Val);
Serial.print(',');
//send to serial: pot3;
Serial.print(pot3Val);
Serial.print(',');
//send to serial: mag1
Serial.print(mag1State);
Serial.print(',');
//send to serial: mag2
Serial.print(mag2State);
Serial.print(',');
//send to serial: mag3
Serial.print(mag3State);
Serial.print(',');
//send to serial: mag4
Serial.print(mag4State);
//end serial line with * and start new line
Serial.println('*');
Step 6: The Code: Processing
The zip file has both the data files (sound clips) and the Processing sketch in the correct folder hierarchy So just download the zip file, extract the folder with its containing files out, and open up the Processing sketch! (If something happened to it, just make sure both the data folder and the .pde file are inside of folder with the same name as the .pde file.)
Notes about the code:
1) The Serial port defined in this code must match the Serial port you have connected your Arduino to. In the setup function, we set the variable port to a Serial object representing the port it will use to read the data. Currently, it is set to the first available port, but if that doesn't work, change the second argument to the name of the port that your Arduino is connected to.
2) We have preloaded two genres of music. To switch between the two, you must set the variable tempo and count to the correct numbers as defined in the comments.
Processing Code:
Sara Montoro
Karl Landin
Alice Lee
Noah Pitts
CNM290/CS294-85
import processing.serial.*;
import ddf.minim.*;
int[] mag = {0,0,0,0};
int[] pot = {0,0,0,0,0}; //The potentiometers are not stored in order. The middle
// connected to pin A3 is actually fed into the Serial after
// all of the other potentiometers. It will be the last value of
// this array (pot[4]).
float volumeCab;
int mot = 0; //motion sensor. (not used)
int cap;
//sound files
String[] songs;
String[] reggae = {"t75bass1.wav","t75drums1.wav","t75horn1.wav","t75guitar1.wav","t75keys1.wav","t75synth1.wav","t75vocals1.wav","t75backup1.wav"};
String[] flamenco = {"t120bass1.wav", "t120drums1.wav", "t120guitar1.wav", "t120guitarSolo1.wav", "t120percusA1.wav", "t120percusB1.wav", "t120piano1.wav", "t120vocals1.wav"};
boolean minimStarted = false;
//IF you wish to choose a different genre, change the below two variables to the ones matching the music you want.
//REGGAE, tempo = 75, count = 1
//FLAMENCO, tempo=120, count=1
int tempo = 75;
int count = 1;
int beat, beatSum, lastMillis, error, mspb, bps;
Serial port;
Minim minim;
AudioPlayer[] players = new AudioPlayer[8];
void setup() {
mspb = count*60000/tempo;
bps = tempo/60;
size(512, 200, P3D);
//NOTE: the second argument in this call must be the name of the Serial Port that
// your Arduino is communicating with the computer through. (On your Arduino Sketch,
// go to Tools > Serial Port. The marked port is the one your Arudino is using.)
// To see a list of available ports, uncomment the below line.
// println(Serial.list());
port = new Serial(this, Serial.list()[0], 9600);
//be able to reach the data directory
minim = new Minim(this);
switch(tempo) {
case 100:
println("Tempo: 100 - No Media Currently Available"); // tempo = 100
break;
case 120:
// FLAMENCO temp = 120
songs = flamenco;
break;
case 140:
println("Tempo: 140 - No Media Currently Available"); // tempo = 140
break;
// REGGAE tempo = 75
case 75:
songs = reggae;
break;
//loadfiles from data folder and the sketch folder
for (int x = 0; x < songs.length; x++){
players[x] = minim.loadFile(songs[x]);
//Request values right away
port.write(65);
for (int i = 0; i < 4; i++){
players[i].loop();
players[i].setGain(-80);
//Minim.start(this);
void draw() {
background(0);
stroke(255);
frameRate(120);
//change volume of stove
players[i].setGain(map(float(pot[i]),0,1023,-80,14));
volumeCab = map(float(pot[4]),0,1023,-80,14);
for (int i=0; i< 4; i++){
players[i+4].setGain(volumeCab);
//keep musical time
if(millis()>=lastMillis+mspb){
lastMillis = millis()-6;
if(beat == 32){
beat = 0;
error = lastMillis%mspb;
print(beat);
print(", " + beatSum);
println(", Error: " + error + "ms");
if (mag[i] == 1 && !players[i+4].isPlaying()) {
//players[1+4].setLoopPoints(0, 5);
players[i+4].play(0);
println("player " + (i+4) + " just started");
//add to beat counts
beat = beat+count;
beatSum = beatSum+count;
println("cap: " + Integer.toString(cap));
//close all audio players and minim
void stop() {
for (AudioPlayer p: players){
p.close();
minim.stop();
super.stop();
//called whenever there is something availble to read
void serialEvent(Serial port) {
//Read the data
String input = port.readStringUntil('*');
if (input != null){
//Splice the String into an array of integers
int[] vals = int(splitTokens(input, ",*"));
//check all values are found
if (vals.length != 10) {
println("ERROR: Only received " + vals.length + " values.");
return;
//Put values into the variables
if (cap != int(vals[0])) {
cap = int(vals[0]);
//start/stop minim
for (int i = 1; i <= 5; i++){
if (pot[i-1] != vals[i]) {
//Watch out! The middle potentiometer is printed out last and will be pot[4]
// because it was the oven in our prototype and not a stove burner like the
// other 4 potentionmeters
pot[i-1] = vals[i];
for (int i = 6; i <= 9; i++){
if (mag[i-6] != vals[i]) {
mag[i-6] = vals[i];
//handshaking
port.write(65);
Step 7: Time to Make Some Music!
When you open a cabinet (or otherwise set off the reed switches), a layer of music will start up. It'll play for a short period of time (or longer depending on how long you've left the cabinet open for). (NOTE: your oven must be on as well for you to hear these layers.)
When you turn on your stove, a layer of music will start up at a volume representative of how high you've turned on your stove to.
When you turn on the oven, the layers of music the cabinets started will play at a volume represented by the temperature your oven is set to.
Step 8: Final Thoughts
Even the type of music is customizable. Just put the sound files into the data folder of the Processing sketch, change the genre to those files, and associate each sound file with a sensor input. We've found that sounds that naturally go together will create a more pleasant ambiance in the kitchen when everything is happening and multiple sounds starting at random times.
Some future ideas for this project:
1) Setup a motion sensor to start up the system (with soft background music) upon entrance into the kitchen.
2) Using a capacitance resistor to sense distance one's hand is from something to control the frequency or tone of the music.
3) Changing genres of music based on time of day/amount of sunlight in the kitchen.
4) Integrate an Ethernet shield so you won't need your computer right next to the set up.
Disclaimer: The code provided here will not be perfect for every setup and might need modifications.
Feedback and suggestions are welcome!
Thanks!
