Introduction: The Recycled Agent Briefcase
This briefcase is a fun craft to make it comes with a case a BB shooting gun (or small hard candy) and a silencer.
For the Briefcase you will need
(1 A cereal box
(2 A moving box
(3 A hot glue
(4 2 Brass fasteners
(5 And a piece of rope about 18 inches
For the gun you will need
(1 A standard art marker
(2 1 small balloon
(3 tape
(4 2 small paper clips
(5 2 medium binder clips (32 mm)
(6 5 2-peg-by-4-peg lego blocks
(7 1 ballpoint pen cap
(8 hot glue
(9 1 gift card
And for the silencer you will need
(1 1 marker cap
(2 1 water bottle
(3 1 sheet of cardstock 22 inches long and 10 and a half inches wide
(4 Tape
(5 hot glue
Optional 1 small sqare tin for ammo
And sorry for the bad photos
Step 1: the Gun
First take the tip out with a par of pliers. Then cut the tip off and pull the bottom of the marker with pliers and take the out the inside of the marker out. then put the balloon on and tape it on.
Take the 2 paper clips and tape them together then bend it as the picture shows and then tape it close to the tip of the marker.
Now take the binder clips and put them on as the picture shows and take the metal pieces off the front one.
Take the 5 lego blocks and hot glue 3 of them together then take the pen cap cut the stick off and glue it to the side of the 3 lego blocks and put the other 2 blocks on.
Now put the lego blocks on as the picture shows and tape it to the binder clips then hot glue the sides of the binder clips and take the gift card and fold the sides till you have three even rectangles and put it on the top of the gun.
Step 2: The Silencer
Take the marker cap and drill the inside out then take the cap of the water bottle and use the marker cap to draw a circle on the water bottle cap .
cut out the circle on the cap and stick the marker cap in it leaving about 3/4 of an inch and hot glue it together. now put some glue in the cap and put it on the water bottle and cut 1 inch of the top of the water bottle.
now take the cardstock and wrap it around the part that you just cut and hot glue it all together.
Step 3: The Briefcase
Take the cereal box and carefully take it apart and hot glue it back together inside out and cut out a lid on one side. now take a piece of carboard and put the cereal box on it and trace a sqare now cut a gun a small rectangle and a sqare in the extra space
(keep the carboard pieces you cut out) if you look at my pictures and you can see i hot glued sides and put the carboard pieces that i cut out on top I don't know the measurements but I know you can figure out and glue it inside the cereal box.
take the fasteners and put them on the corners so when you close the lid you can use the fasteners to keep it closed by puting 2 small holes in the lid.
and to finish it off take the rope and glue it to the cereal box.
