Introduction: The Remote Controlled Stop Light
This Stop Light gets controlled by a remote.1 is Red,2 is Yellow and 3 is Green. Use this for races or your tournaments.The stop light will stay on one color for 5 seconds.If you push 1 you have to wait 5 seconds to push the next.
Red Led
Green Led
Yellow Led
Wires
Receiver
Remote
220 Resistors
Arduino
3D Printer
Hot Glue Gun
Step 1: Printing
First Print The Stop Light and Hot Glue the 3 Pieces together.Next put paper or Plastic over the coverings,
Step 2: Wiring
Next Complete the Wiring shown in the Pictures.The Resistors are 220.Here is the Code that you will need for the Arduino.
#include <IRremote.h>
//Define Pins
int redLed = 5;
int yellowLed = 4;
int greenLed = 3;
int RECV_PIN = 11;
//IR Library stuff
IRrecv irrecv(RECV_PIN);
decode_results results;
void setup()
//Set Led Pins
pinMode(redLed, OUTPUT);
pinMode(yellowLed, OUTPUT);
pinMode(greenLed, OUTPUT);
//Enable serial usage and IR signal in
Serial.begin(9600);
Serial.println("Enabling IRin");
irrecv.enableIRIn();
Serial.println("Enabled IRin");
void loop() {
if (irrecv.decode(&results)) {//irrecv.decode(&results) returns true if anything is recieved, and stores info in varible results
unsigned int value = results.value; //Get the value of results as an unsigned int, so we can use switch case Serial.println(value);
switch (value) {
case 2295:
digitalWrite(redLed, HIGH);
delay(10000);
digitalWrite(redLed, LOW);
break;
case 34935:
digitalWrite(yellowLed, HIGH);
delay(10000);
digitalWrite(yellowLed, LOW);
break;
case 18615:
digitalWrite(greenLed, HIGH);
delay(10000);
digitalWrite(greenLed, LOW);
break; }
irrecv.resume(); // Receive the next value } }
Step 3: Testing
Next test it with your remote and point it at the receiver.
