Introduction: The Blue Rope Chair
A project about repairing a broken chair.
By Olivia Sahl
Step 1: Find an Old Chair Thats Missing Something
I was really lucky to find this chair at a thrift store for free!
Step 2: Find a 10mm Thick Rope
At first i wanted to cover the hole chair in rope, but the metal part of the chair was actually in nice condition so i had to show it.
I found this nice blue 10mm rope from my local hardware store, but the ideal would deffently be to find rope at a thrift store to have a 100% environmentally friendly chair.
You also need a 0,6mm thin polyester thread to close the ends of the rope.
Of course you could always switch up the colours according to your taste.
Step 3: Get Weaving!
I started of by securing the rope to the chair with a clove hitch in the right corner og the chair.
Then you pull the rope around the one side and then over to the other side. I had to continue this process 17,5 times to cover the seat of the chair.
Then i closed of the weaving by doing a clove hitch in both corners of the chair.
Know the rope is secured on the chair.
Step 4: The White Closings
To close of the ends you have to twist the thin white thread around the ends in 2 layers, and then melt it in place. You also have to melt the thick end of the rope to correctly secure it.
Step 5: The Missing Metal Rod Replacement
My chair had a missing metal rod and that is being replaced with the blue rope.
Firstly you have to drill a hole which the rope can come though. I used a 10mm drill and then filled the edges.
Then tie a clove hitch on the top of the chair and then just a normal knot in the other end.
And then do the last melting and twisting to close op the ends of the rope.
