Introduction: The Save Using Arduino
The Save Using an Arduino
Arduino
Pin Board
touch sensor
light strip
2 buttons
servo motor
6 pin to alligator connectors
6 pin to pin connectors
Box
Step 1: Step 1: Plan and Create the Box
The Box should have 2 compartments.
One compartment should fit all the hardware and the other should be the save storage itselfe
Step 2: Step 2: Drill Holes, Cut-out for the Servo Motor
2 holes for the buttons
1 hole to power the Arduino
(if your box is large enough you could also put the power source into the hardware compartment)
make one cut-out for the servo
Step 3: Step 3: Install the Buttons, Touchpads and Servo
Install both buttons
glue 4 pieces of aluminum foil to the lid of the box
screw or glue the servo front piece of the box
Step 4: Step 4: Assemble the Box and Connect the Hardware
Glue together the box (except lid)
connect buttons, touchpads, light strip and servo to the pinboard
test out the code
make sure that no connections are loose
Step 5: Step 5: Arrange Angle of Servo, Install the Door
glue on the lid
then configure the servo so that the door opens without problems
