Introduction: The Secret PIN Number
Have you ever forgot the PIN number even though you use the credit card every day?
It happened to me (more than once).
Last time I went to the Scotland, I could not take out any money as I forgot the PIN number.
It's interesting how you can suddenly forget the number combination that you use every day.
Luckily it came back to me the next day. The trick is to let your hands/fingers do the thinking not your brain :)
They say you should never carry a written PIN number inside of your wallet. If somebody will steal it, they will most likely find the PIN and use your card.
I personally think it's OK to write down your pin as long as you encode it and hide it.
You could always write down your PIN one way and read it the other way.
For example: The pin 1234, could be read as 4321 or 2314, 2341 etc.
Not secure enough?
Let's hide the pin number in the plain sight.
What's needed:
- Thermochromic Pigment
- Access to the printer
- Paper, cardboard, glue
- Nail Polish or in my case Gel effect Nail Polish
If you are Interested in the video version of this Instructable and the embedded video does not appear on your mobile device, here is an alternative link
Step 1:
I mixed the pigment with gel effect nail polish.
Step 2:
I printed out a fake business card and artwork with a PIN number on it.
The pin number was printed with a light blue ink - a few shades lighter than the pigment.
Step 3:
I glued the business card on top of the cardboard to make it thicker.
Step 4:
Then I painted the paw blue.
Step 5:
Thermochromic pigment will become transparent when heated.
I heated up the paw with a hair dryer and cut it out.
Step 6:
Then I glued it to the business card.
Step 7:
That's it!
If somebody will steal your wallet, thief will not know that the business card has a PIN number written on it.
If you ever forget the PIN number, just warm up the paw with your finger to see it.
PS.
There are different temperature pigments available.
I used 31C (87F) pigment, but I have also done it with 33C (91F) pigment and it worked fine.
31c, 33c - That's the temperature when the pigment will start to change the color.
There are also lower temperature pigments available.
28C, 21C and even 18C. Lower temperature pigments are great if you want to use more layers of nail polish, but I don't like the way it looks with a thick layer. Keep in mind that low temperature pigment+thin layer of nail polish might make the pin number appear even without touching it (if it's hot outside or the wallet is very warm). With 31c - 33c pigment the layer can't be too thick, otherwise it will take you ages to heat it up with your fingers. So if you use a 31c - 33c pigment, you have to find the balance between the right shade of font color, quantity of the pigment you put in the nail polish and the thickness of the layer.
