Introduction: The Shadow Sniper
The Shadow Sniper is designed to produce maximum range with minimal rubber bands.With just 1 rb this gun can fire around 45ft and with 2 60+.My new gun also has a brand new bullet locking mechinism designed with little fiction to increase the power further!.
Remember if you like it +1 Rating!!
Step 1: The Peices You Will Need
These are the peice that you will need to build the gun :)
Rods
grey (sharpened) 1
grey (normal) 5
Red 9
Blue 1
white 4
Green 5
Connectors
Grey 23
Light gray 1
Orange 4
Red 3
Green 2
Yellow 7
Tan clip 13
Hinge 1
Half gray 4
Ball socket 1
Ball joint 1
Black clip 3
Other
Blue spacers 63
Total
152
Rods
grey (sharpened) 1
grey (normal) 5
Red 9
Blue 1
white 4
Green 5
Connectors
Grey 23
Light gray 1
Orange 4
Red 3
Green 2
Yellow 7
Tan clip 13
Hinge 1
Half gray 4
Ball socket 1
Ball joint 1
Black clip 3
Other
Blue spacers 63
Total
152
Step 2: Back of the Gun
To start off u should build the back of the gun, follow the pictures to find out how
Step 3: Back of the Gun Part 2
Next,Constuct the peice shown in the picture and attach it to the end of the 3 grey rods that were in the prevous step
Step 4: Middle of Gun
This part of the gun holds both parts together and is very important, as i said before follow the pics
Step 5: Bullet Locker
This is the bullet locking mechinism i was on about so follow the pictures carefully, (BTW the greyrod is supposed to bend a little)
Step 6: End of Gun
This is the end of the gun where the rb will be, Follow pics
Step 7: Ammo Holder
The ammo hold can store 5 of either yellow rods or blue rods depending on you own choice, add 2 blue spacers then 2 orange connectors where shown and connect the ammo holder to the orange connectors, FTP
Step 8: Trigger
this is the part of the gun that makes it fire so follow pics carefully!
u need to add a hinge connector to the trigger in the previous pic and the other end to a new part in the middle of the gun :)
Step 9: Handle
This is the easiest part of the gun to make so just follow the pics
Step 10: Fireing Pin
The firing pin remember must be sharpened so just follow the pic
Step 11: Adding Rubberbands
There fistly is the main rubber band which goes on the front of the gun and end of the firing pin as shown below.
and the second one strecths from the trigger to the front of the gun as well.
Step 12: Where to Put the Ammo and Bullet
Firstly you put the bullet into the gun as shown until it firmly in place.
then put the ammo where shown in the picture and to get a bullet simply tilt until one falls out.
Step 13: Optional Extras
This is a redeisned fireing pin that can stand more force than the other pin also it is easier to pull back but this one weakens the gun slightly because it is heavyier so that is why i have not included it in my final design, anyway the other one is just as capable to stand up to the force that is nesseresary. Its your choice :)
note: I use 100mm X 30mm rubberbands
ENJOY!
ENJOY!
