Introduction: "The Solar Baby" Solar Oven, Cooker.
Another Solar Oven made mostly of recycled material. It is gimbled so cooking pot stays level while oven rotates. Lightweight and breaks down into 2 pieces for storage.
Step 1: "Solar Baby" Solar Oven
The Solar Baby (named by Aunt Phylly) is a small solar oven made of recycled materials. It reaches 325 degrees in the winter Arizona sun. All measurements are determined by the size glass that you find. Tempered glass is recomended as it gets very hot. You can build this bigger, I had one that would cook a whole chicken in 2 hrs.
Step 2:
For this oven I found an 8x10 picture frame for 99 cents at Goodwill. The wood from a remodel we walked by. Had to buy hinges and latches from a recycle store. 2 big popcorn cans, fiberglass insulation from a construction site. Aluminum paint roller tray grate 1.99 at walmart, metal coat hanger, Alumimum foil. Most of the work was done with a dremel tool and saber saw. 1/2 the outside length determines the radius of the outside dremel cut. another cut 3/4 inch inside for the inside tin. Build the stand 1/2 inch wider than the curved oven. Elmers glue for the aluminum foil ends
Step 3:
The reflectors are 1/8 plywood set at a 60 degree angle. Beveled edged for a good Gorrilla Glue seam. Glued on aluminum foil. Glued the reflectors to picture frame. Used 2 removable pin hinges and 2 latches between wood picture frame and curved box.
Step 4:
The reflectors hinge foward to load the oven and can be removed and stored inverted over the top of the cooker. The pin in the side adjusts the cooker to the sun angle. 305 degrees in January. I used coat hanger wire to suspend a grill cut from the paint roller grill and double nutted them to the pivit bolts so the grill stays level when the reflectors and oven rotate . Hope this helps you get started on a fun and useful project. If you like this project I am entered in the Shopbot contest and would like any votes i can get. Thanks for looking.
