Introduction: The Splatter 6-Wheel Vehicle
We are going to teach you how to make a 6-Wheel Splatter Vehicle that splatters people with ink (it doesn't have to be people). :D
Step 1: Materials
1. 2 wooden blocks or 1 big wooden block
2. 2 4-battery holders (with on-off switch)
3. 1 2-battery holder (with on-off switch)
4. 7 motors (relatively small)
5. Hot Glue
6. Tape
7. 1 Markers
8. Hot glue sticks
9. Cardboard or Foam material (for the wheels)
10. Scissors
Step 2: Assembling the Base
Glue 2 wooden blocks together.
Step 3: Putting the Battery Packs On
Hot Glue the battery packs on. Make sure that you leave some space on the bottom for the wheels.
Step 4: Putting Together the Wheels
Cut out 12 cardboard circles that are relatively small.
Use the motor and poke a hole in 6 of the circles. (only 6! (not 6 factorial))
Insert some hot glue into the holes.
Put the cardboard circles back onto the motors.
Hot glue the other 6 cardboard circles on the already glued wheels. (like a double layer) This makes sure that the wheels can support the weight of the entire vehicle.
Step 5: Putting Together the Vehicle
Hot glue the motors on the bottom of the vehicle.
Wire the motors so that they all turn in the same direction.
Step 6: Putting the Weapon On
You have one more motor left. Glue it at the front top of the vehicle. Then drill a hole on the back of the marker. Put a bit of hot glue inside of the hole and stick it into the motor. It will splatter even with the cap on! Well, have fun! :D
Step 7: Final
Your project is done! Enjoy! Have fun splattering people! :D
