Introduction: The SporkBrush?
I was looking through my gear one day, trying to find a way to shave some weight off of my pack, when I thought of this. A SporkBrush. This is one of those gimmicky inventions that looks awesome and makes sense(at least to some people), but probably won't ever be of actual use. It weighs in at only 2g. 2g! Although it is much bigger in your mouth then the average toothbrush.
Materials:
- Toothbrush
- Superglue
- Rubber thingy from Meccano(https://www.meccanospares.com/23c-BK-O.html)
Tools:
- Hacksaw
Step 1: Cut Toothbrush
Cut the toothbrush off of the handle. Sand to make it smooth, otherwise it will probably hurt your mouth when you brush.
Step 2: Glue Rubber Piece to Toothbrush
Apply some glue to the toothbrush and glue the rubber piece on. Try to make it into a kind of oval shape, to fit better into the spork.
Step 3: Attach SporkBrush to Spork
Squeeze the rubber piece through the hole in the spork. The notch in the rubber should fit right in the hole in the spork. Done! You can now brush your teeth with style while camping or hiking.
