Introduction: The Symmetrical Magic Square
This instructable will show you how to construct a magic square that is symmetrical.
The matematical truth that a key pads entered path sequence added with its own 180 degrees rotated sequence always results in n*1's and ends with a 0, inspired me into this discovery which might be known, but I thought I would share it with you because I havent seen it other places.
Key Pad:
- 1 2 3
- 4 5 6
- 7 8 9
Examples:
15 + 95 = 110
186 + 924 = 1110
1236 + 9874 = 11110
18342 + 92768 = 1111110
This can also be expressed as: KeyPad(x,y) + KeyPad(2-x,2-y) = 10
Step 1: The Symmetrical Magic Square
There are many ways of constructing a magic sqaure, but I will only show you mine.
Conditions: The 2D matrix must be bigger than 3 and always be odd in size.
The function:
f(y) = 2*x mod Size
OR
For x = 0 to Size-1
Matrix((OffsetX + x) mod Size, (OffsetY + 2*x) mod Size) = Nr
next
Now we have a magic square, but is not symmetrical or concentric, so we rotate the matrix 180 degrees and add them together.
For x = 0 To Size - 1
For y = 0 To Size - 1
Matrix(x,y) = Matrix(x,y) + Matrix(Size - x - 1, Size - y - 1)
Next
Next
Then we mirror the original matrix and add it to the above added together.
Matrix(x,y) = Matrix(x,y) + Matrix(Size - x - 1, y)
Next
Next
The result is a symmetrical magic square.
You can run a new f(y) =2x*mod Size on top of the old matrix and then repeat the 180 degress and mirror operation forever.
Matrix of same size with same operations applied can be added or subtract from each others. Multplied or Divided with a constant and will still be symmetrical magic squares.
Download my Visual Basic 2010 program and source code to play around.
