Introduction: The SynthCat 4000
Is it a synth, is it a cat... It's a SynthCat 4000!
You can find a video of this beastie here: https://youtu.be/AViN59aRU58?si=wULrvJ-bv8XBa1NO
This is a super basic little project based electronically and lets face it physically on an Arduino UNO. Print out a few parts, hook up the 2 pots and audio plug, upload the code and you're good to go.
Two basic controls: the head controls the frequency and the tail controls the modulation.
Parts:
2x 10k PCB mount potentiometers
1x Arduino UNO
1x Wire about 1 meter
1x 3.5mm audio socket
3x Header strip (this normally comes with the Arduino)
1x Heat shrink a few centimeters
A small amount of filament for 3d printing.
1x USB cable for power and to program the Arduino
Tools:
3D Printer
Computer to program the Arduino
Soldering iron
Solder
Side cutters
Hot glue gun
Step 1: The Fun Printing Part
Print the parts; go the the link and print the parts in the colours of your favourite cat. https://www.thingiverse.com/thing:6574190/files
I printed it all in one go with supports only on the head and tail connectors.
Step 2: Getting Started on the Board
Cut the 6 ISCP pins (sometimes they are not there) flush using side cutters. This will allow the head connector to fit.
Step 3: Soldering
Wire up the 2 pots and the audio connector. I used heatshrink to make it tidy.
Connections:
Audio connector + to Arduino Pin 11
Audio connector - to Arduino GND
Head pot left to Arduino GND
Head pot middle to Arduino pin AO
Head pot right to Arduino 5V
Tail pot left to Arduino GND
Tail pot middle to Aduino pin A1
Tail pot right to Arduino 5V
Step 4: Fitting the Printed Parts I
Add the head and tail connectors, you can use a little hot glue here to keep them stable if you need.
Step 5: Fitting the Printed Parts II
Add the legs. You can use a little hot glue here to add stability.
Step 6: Mount the Pots
Slide the 2 pots up into the head and tail supports. The pot connected to A0 on the Arduino is the head and the pot connected to A1 is the tail. A little hot glue can be used here for supports.
Step 7: And I'll Form the Head
This is it, time to place the head and tail.
Step 8: Programming
Now we need to program your SynthCat:
- Download the Arduino IDE
- Add the "the_synth" library. If you are unfamiliar with adding libraries just do a search for "add Arduino library" This is the link to the library: https://github.com/dzlonline/the_synth
- Download my CatSynth 4000 file and upload it to the Arduino.
Step 9: Play
This is it, you have done it.
The real fun starts here, now you can modify the Arduino file to create a different sounding kitty or modify the STL files for a different looking kitty.
I really hope you have fun with this project, I'm always here to help if you run into any problems.
Happy noise making...
