Introduction: The Ultimate Anvil Stand!
I finally decided it was time to build an proper anvil stand. Unfortunately i've come to find out that most floors/surfaces are not truly level. By going with 3 legs you can eliminate wobbling due to an uneven or nonlevel floor. I splayed the legs at 10 degree angles for better stability. This was a very fun build, that only took about a day and a half.
As with most of my instructables, there are a handful of details and tricks in the video that aren't in the image gallery, so if you have the 7:00 to watch the video, I highly encourage you do so!
Tools & products used:
Lincoln Electric 140C Mig welder - http://amzn.to/2fhWbGd
General tools angle finder/miter gauge - http://amzn.to/2fhWbGd
Dewalt 4 1/2 Angle Grinder - http://amzn.to/2fhWbGd
Dewalt Flexvolt Angle Grinder - http://amzn.to/2fhWbGd
Dewalt DW862 Cold Saw - http://amzn.to/2fhWbGd
Sculpt Nouveau Cleaner & Degreaser - http://bit.ly/2lIJQd6
Sculpt Nouveau Copper Plate Patina - http://bit.ly/2mDTdjj
Lacuqer clear coat - http://amzn.to/2mDXF1G
Step 1: Finding the Correct Height
Convention has it that the face of the anvil should be at the height of your clenched fist. Getting this measurement was the first step. In my case the top of the anvil should set at 29.5".
Step 2: Crunching the Numbers
The next step was to subtract out the height of all the materials. This left me with the total height the legs needed to span, however, I decided to splay the legs at 10 degree for better stability, which necessitated some basic trigonometry.
See, it can actually be useful!
Step 3: Raw Materials
The raw materials for the build:
2x3 steel tubing
1/2" plate steel
1/4" plate, and a 2x12".
Step 4: Setting the Miter
Using a bevel gauge to set the saw to cut the legs at 10 degrees.
Tools pictured:
General tools angle finder/miter guage - http://amzn.to/2mq4AuP
Dewalt DW862 Cold Saw - http://amzn.to/2etobWb
Step 5: Chop Chop!
Using a cold saw to cut the legs to length at 10 degrees. Loudest tool in the shop hands down!
Tools pictured:
Step 6: Drilling Hole for Fastening Bolt
Here I have everything mocked up in place, I'm drilling through the 2x4 which will also leave a mark on the 1/2" plate. The anvil will be secured with two bolts passing through this hole.
Step 7: Drill!
Here I'm drilling a 3/8" hole through the 1/2" thick steel plate. The drill press made relatively quick work of this.
Step 8: Test Fit
Success! I decided to use a wood block for a couple reasons:
1. It will dampen the vibration & ringing of the anvil
2. If I ever go with a taller anvil, I will have a couple inches leeway.
Step 9: Weld the Legs
Pretty much what is sounds like. I put a few tacks around each leg before welding solid to avoid heat warping.
Tools used:
Step 10: Welding in a Tray
Welding some 1/8"x1" flat stock across the legs where I will be adding a tray. The tray wasn't necessary for strength, but I figure it would be nice to have a place to set my punches and drifts, etc. Also, If I need extra weight, I could umm--put heavy things in it.
Tools pictured:
Step 11: Sand!
So metal anvil stands are great, however there are two fairly common complaints:
1. Not heavy enough unless bolted down
2. Loud! Metal doesn't do a very good job of dampening vibrations
The sand will mitigate these issues.
Step 12: Feet!
The next step was to weld the feet on the bottom of the legs. I had to do this upside down in order to keep the sand in the legs. I also predrilled the feet in case I ever decide to bolt down the stand.
Step 13:
Alright, here the frame of the anvil stand is complete, I also just blasted it with some copper plate patina, I wanted to do something a bit different and this turned out neat. I'm a big fan of Sculpt Nouveau products and use them quite often in my builds.
Products used:
Step 14: Leather Hammer Holders
This was my first foray into leather working, and even without the proper tools, I was very pleased with the results. I look forward to including more leather in my future projects.
Step 15: Installed
Here you can see the leather handle holsters installed. I drilled out and tapped the frame, punched out the leather with an awl, and bolted them directly to the frame.
Step 16: Close-up!
Very happy! I didn't intend on the design looking like a Soviet Union propaganda poster--but oh well.
Step 17:
The natural wood, just didn't jibe with the rest of the stand, so I decided to do the "Shou sugi ban" process on it. This also has the benefit of preventing the wood from moisture and rot--and it's fun to say.
Tools used:
generic propane torch/weed burner - http://amzn.to/2igRlXd
Step 18: All Finished!
I had a lot of fun with this build, I got to play around with some new metal patinas, experiment with some basic leather working, and use trigonometry!
Thank you for checking out this Instructable! If you'd like to see more projects from me, make sure to subscribe to my YouTube channel ZH Fabrications and check out my website www.zhfabrications.com.
And again, here are the tools I used for this project:
Dewalt 4 1/2 Angle Grinder - http://amzn.to/2mq4AuP
Dewalt Flexvolt Angle Grinder - http://amzn.to/2mq4AuP
Dewalt DW862 Cold Saw - http://amzn.to/2mq4AuP
Thank you,
Zack
