Introduction: The Ultimate Knex (Autoload) Rifle
So this is my favorite design of all my knex rifles and the first one i have posted on this site. This rifle uses a hopper to reload. I usually made my hoppers out of a plastic or cardboard material which worked very well. But oodalumps had a hopper that used all knex pieces so I just borrowed his idea with slight modifications.
Step 1: Construct Firing Pin
1 black/grey rod
2 blue rods
1 red connector
1 grey connector
1 blue and purple joint connector
2 blue rods
1 red connector
1 grey connector
Step 2: Construct Back Handle
4 green connectors
2 blue and purple joint connectors
3 red connectors
2 orange connectors
12 yellow connectors (as many or few as you want)
4 green rods
5 blue rods
2 red rods
3 white rods
3 red connectors
2 orange connectors
4 green rods
5 blue rods
2 red rods
3 white rods
Step 3: Construct Ammo Hopper
12 grey connectors
2 light grey connectors
4 orange connectors
2 white connectors
5 yellow rods
4 orange connectors
2 white connectors
5 yellow rods
Step 4: Construct Barrel (part 1)
15 peach connectors
1 orange connector
4 yellow connectors
3 red rods
1 orange connector
4 yellow connectors
3 red rods
Step 5: Construct Barrel (part 2)
add a grey rod connected to a orange connector to the step 4 barrel
picture shows bottom view
Step 6: Construct Barrel (part 3)
add 11 grey connectors to fill in the gaps in the barrel
Step 7: Construct Trigger
1 orange connector with rubber band slipped through hole
2 grey connectors
1 blue rod
2 grey connectors
1 blue rod
Step 8: Add Trigger to Barrel
connect the blue rod to the orange connector of the barrel. connect it so that the orange connector of the trigger is separated by the orange connector of the barrel by the two grey connectors
Step 9: Construct Front Handle (part 1)
2 white connectors
3 orange connectors
2 yellow rods
2 blue rods
3 orange connectors
2 yellow rods
2 blue rods
Step 10: Construct Front Handle (part 2)
add two more red rods on either side of the original red rod
Step 11: Construct Connection of Handle to Barrel
two objects:
1st:
1 light grey connector
2 yellow connectors
5 green rods
1 grey rod
1 red rod
2nd:
2 red connectors
5 green rods
1 grey rod
1st:
2 yellow connectors
5 green rods
1 grey rod
1 red rod
2nd:
2 red connectors
5 green rods
1 grey rod
Step 12: Connect Step 11 Objects to Barrel
turn barrel upside down and place step 11 objects next to it like the picture.
connect green connectors of the step 11 objects pointing toward barrel to all but one of the barrel's yellow connectors. The green connectors will connect to the diagonal claws of the yellow connectors
Step 13: Connect Handle to Barrel
connect step 10 handle to the barrel. The light grey connectors on the barrel are at the front of the gun. So place the step 10 handle with the white connectors connecting to the green connectors of the barrel. The yellow rods of the handle should be pointed toward the front of the gun.
Step 14: Connect Hopper to Barrel
This step is easy. Simply connect the orange connectors of the hopper to the red rods of the barrel. Put the orange connectors in the gaps of the peach connectors. There should be three peach connectors inbetween the orange connectors of a side and two peach connectors on the outside.
Make sure that the light grey connectors are close to the back orange connectors (not the front orange connectors)
Step 15: Construct Wheel System
This is optional but recommended.
First construct two small objects as the first picture shows.
Each small object has:
2 orange connectors
2 red connectors
2 white rods
Then construct the wheel hold which consists of:
2 red connectors
2 white rods
2 blue rods
1 yellow rod
2 small wheels
Connect the two small objects to the wheel hold as shown in the second picture
2 orange connectors
2 red connectors
2 white rods
2 red connectors
2 white rods
2 blue rods
1 yellow rod
2 small wheels
Step 16: Connect Wheel Hold to Barrel
The orange connectors of the wheel hold will be connected to the yellow rods of the handle (step 9,10)
Connect them so they are next to the three orange rods on the handle. Then connect the two white rods of the wheel hold to the light grey connectors of the hopper
The second picture (although blurry) shows sentences 1 and 2
Step 17: Connect Back Handle to Barrel
Connect the step 2 back handle to the barrel.
Connect the green connectors of the back handle to the blue connectors of the front handle (step 9,10)
Then connect the top blue and purple joint connector of the back handle to the grey rod coming out of the back of the barrel
Step 18: Connect Rubber Bands
Connect the rubber band of the trigger to the closest blue rod of the front handle (part 9,10). Depending on the strength of the rubber band you might need to wrap it around the blue rod several times so its tight (1st picture)
Then put two rubber bands on firing pin so they are encircling the blue rods (2nd picture)
Then slip firing pin in barrel with grey connector (the hole part of it) of pin sliding in the grey rod shown in step 17. Wrap the rubber bands of pin around the wheels (3rd picture) and then slip on the tip of the two highest red rods of barrel (4th picture)
