Introduction: The Werewolves of Miller's Hollow (狼人殺) Circuit Helper
This project is made for people who like to play The Werewolves of Miller's Hollow, and this box is used to play with 8 people, with three werewolves, two villagers, and three special roles (Seer, Witch, and Hunter). This box is made to replace the host, and automatically run main 4 phases of the game (which are "wolf decide to kill", "Witch decide use potions", "Seer examine", "discussion")
Simple rules: Click Here
Parts :
Botton (top) -> press to start the game
Botton (bottom) -> use to skip a phases
Two blank square (below LED board) -> use to write the number of people werewolf killed and killing potion that with wanted to use
Eight liftable character cardboard -> use to let seer check the identity of the people
A large square space -> use to place character cards
LED ->show present phases of the game
Cardboard
Paper
Buttons
LED lights
LED board
Wires
Breadboard
Step 1: Step 1 : Building the Box
Cut Board into:
two 25cm * 18cm
two 25cm * 5cm
two 18cm * 5cm
one 14.5cm * 15cm (will be used after finish step 2)
Use Tape to stable and joint of the boards
Step 2: Step 2 : Cut Squares
Cut the following size of squares:
Largest square : 10cm * 7cm
Squares beside button (two) : 4cm * 3cm
Eight small square : 4cm * 2cm (use tape to make the square able to be lifted) (you can add more to make
it becomes easier to be lifted)
Square of LED board : 2cm * 9cm
Two circles : Diameter of your button (diameter of 3cm in the example)
Step 3: Step 3 : Electric Circuit Chart and Code
Code : Click Here
Step 4: Step 4 : Video
This is my video : Click Here
