Introduction: The X288 SERPENT
Step 1: The Top of the Barrel
The top part of the Barrel.
Step 2: The Bottom of the Barrel
The bottom part of the Barrel
Step 3: The Ram
The big ram.
Step 4: The Side Plates
Make two of each, and attach to both sides as shown.
Step 5: The Pseudo-Magazine/Club
This a false Magazine that is best used as a club.
Step 6: The Small Frontal Bit
A tiny piece.
Step 7: The Demented Frontal Shell
The front part.
Step 8: The Handle
The part to which one holds on.
Step 9: The Front Side Plates
These will connect steps 7 and 8.
Step 10: The Bottom Brick
This piece sits at the bottom.
Step 11: The Hinge-y Trigger
These hinge-y parts will become the trigger.
Step 12: The Top Brick
The top part.
Step 13: The Other Plates
Plates that protect the trigger.
Step 14: The Back Brick
This part sits at the back
Step 15: The Pull-Down-Er
This activates the weapon.
Step 16: The Stock
Your shoulder rests here.
Step 17: The Handle and Connection
Your hand rests there. Also, connect.
Step 18: How to Use
To Load, Pull back the Giant Ram and pull up. It should snap into place, If not, try again. Also, don't overload on rubber bands... If you do, the grenade will explode upon firing.
Step 19: Regular Fire Adapter
If you want to fire regular rods, make this and place it in picture 2 when needed. When not needed, place in picture 3.
And then... you are done.
FIN
FIN
