Introduction: The Amazing Steampunked "Ticker Machine"
Hi everybody!
A couple of month ago I build Dr. Brain .
Dr. Brain is able to listen, to see and to talk.
But he is not bale to write.
So I build the amazing "Ticker Machine" for Dr. Brain and other calculating devices with
a seriell interface.
It is easy to build the parts are easy to get.
Step 1: Parts and Materials
You need:
a thermo printer (this is operated by 24V and has a serial interface you can buy this on ebay)
a wooden plate or something similar
a glas dome hat fits on the plate
a box or a paper tube for the stand
some stain
some pieces of beach wood fpr the paper holder
some brass parts, screws, nuts and gears.
And don´t forget to "glue some gears on it" ;-)
Step 2: Build the Printer Stand
First I cut the paper out slot and drilled the holes for mounting the printer to the top and the electronics to the bottom of the plate.
This quite a bit tricky because I like to have the printer visible. So I have to build something that guides the paper from the printer through the glass dome to outlet.
I used some thin wood and bend it a bit then I glued it to the wooden plate as shown on picture 5.
Step 3: Building the Paper Holder and the Stand
The paper holder was build from beach wood.
I used the original holder for the paper roll as a part of the holder to make it easier adjust the right distance between the holders.
Than it was mounted and adjusted behind the printer.
Some gears to make it a bit more "mechanical".
Than I glued the plate to stained paper tube.
The Paper tube was glued to the base stand as well.
I attached four brass feet to the base stand.
The base stand is open on the bottom, so it it possible to connect the 24V Power supply and serial cable to the printer.
The small glas tube on the front indicates "power on" and was made from an old water gauge.
Step 4: Operate It
The printer comes with a standard windows driver.
With this driver, you can control the feed, the font and the cutter of the printer.
I used the scheduler of WINDOWS to print messages.
To do so you have to schedule a task and execute a BATCH - File that prints the message.
Both the notepad and write can be called with a command line parameter to print on the default printer:
@echo off
write.exe /p message.doc
this will print the file message.doc (created with write.exe) on the default printer.
So it is possible to to print time based messages.
In the internet, you can find thunderbird 3.x and an addon that is called autoprint.
If you install this on the computer where the printer is connected with, it is possible to auto print emails.
This is a very funny feature.
So have fun everybody,
H. Steam
Hurricane Lasers Contest
20 Comments
9 years ago on Introduction
What a fantastic idea! I might just have to make one of these. Thanks for the idea!
Aether Telegram:
CONGRATS!
YOUR PROJECT HAS BEEN POSTED IN:
Hack-A-Day.
Please click HERE to connect to the
Aetherweb Node hosting the said Article.
There is also a chemically made painting attached to this telegram.
*Please be aware that these paintings have been know to spontaneously burst into flames.*
Sincerely Delivered by
EFW Systems' Aether Modular Connection.
I am really proud about it :-)
Thanks a lot!
I visit Hack-A Day several times a day,
mainly for inspiration...
I'm actually surprised at the number of people from here,
I see on there...
Anyways, wasn't one of your other 'Ibles feature before on Hack -a - Day?
Also be careful with that digital painting!
9 years ago on Step 4
Nicely done and a very cool re-invention of a teletype. a hardcopy of an email coming through is so cool.
You never cease to amaze Mr. Steam! More steampunk genius! I'd love to see a video of Dr. Brain “talking” to the ticker;-) 5 stars, since that's all I can give, plus a vote in the laser challenge.
you never cease to amaze me bro. five stars though i would've given you 23 stars. after that message i encourage you to make more like this.
Thank you very, very much :-)
Where do you get Glass domes this big ?
Good Morning,
I bought it from Selva: www.selva.de
And here is the direct link to the domes: CLICK you can also buy a wooden stand for the dome No. VI.
I used the dome No. VI for the printer.
With kind regards,
Horatius Steam
Great style, I love it!
5 STARS!!!!....
Completely awesome to have the autoprint emails come out! I have seen other instuctables that pick up tweets and other incoming messages.. Heck, if people still used faxes, that would be funny, too (except for the junk faxes advertising discount travel).
We are using this in RPG´s to guide the players and give them hints and messages.
With kind regards,
H. Steam
Dear Sir Horatius.Steam
Once again an absolutely crazy object!!!"
Five stars worth and given ;-)))))
Yours Aeon Junophor
I hope you've entered this into the laser contest?
Nop, there is no laser inside....
Sorry, this was a misunderstanding by me. Thank you for the advise.
I just entered it. :-)
Excellent.
Marvelous!
