Introduction: The Perfect Pizza Cutter
Have you ever had the trouble of making pizza? Well this revolutionary pizza cutter cuts the perfect pizza dough circle to put toppings on and cook. Then when its cooked it will cut the pizza into slices
Step 1: Materials
You need:
JB Weld
about 18 inches ofsmall aluminum square tube
a stainless or galvanized nail
3 pizza cutters
Tools:
hacksaw
drill
drill bits
clamp(optional)
ruler or yardstick
JB Weld
3 pizza cutters
Tools:
hacksaw
drill
drill bits
clamp(optional)
ruler or yardstick
Step 2: Cut to Length
Use the hacksaw to cut the aluminum tube to length. Feel free to make it to any length. Although, it must fit on your pizza pan.
Step 3: Mark the Middle
take a ruler and measure the tube to find the center
Step 4: Cut the Center
drill a hole in the center of the tube and go all the way through.
Step 5: Hack the Cutters
use the hacksaw to cut the wheels off the handle of the pizza cutters
Step 6: Bend
Bend the top of the cutters to a 90 degree angle
Step 7: Conect the Cutters
Glue the cutters to each side of the tube.
Step 8: Add the Last Cutter
Add the last cutter to the top of the tube. Be sure its not in the way!
Step 9: Add the Nail
Put the nail into the center hole you drilled and glue it in with jb weld or super glue.be sure to glue in the nail so that it doesn't point out more than the pizza cutters.
Step 10: DONE!!!
huray! you made it this far and now its time to make some pizza!
1. roll out some dough and cut a circle out with the cutter
2. put toppings on
3.bake
4.cut the pizza withe the top cutter
2. put toppings on
3.bake
Step 11: Improvements
I was thinking that instead of three pizza wheels , how about 2 and one pizza chopper at the top. Also you could make it so that the cutters slide along the tube to make different sized pizzas.
