Theatrical Effects: Replicating a Pyrotechnic Effect Without Any Pyro
Intro: Theatrical Effects: Replicating a Pyrotechnic Effect Without Any Pyro
The effect that I am going to be replicating is a firecracker. The effect needed to produce a large quantity of light in a very brief period of time, mimicking the flash from a firecracker, or an airburst, or a small amount of flash paper. The flash that is required is larger than usual, because theatrical lighting is much brighter than usual, around the house lighting.
Here is a video of the demo board that I created for this Instructable. I apologize for my camera's inability to adapt to the rapid flash from the device.
STEP 1: Different Methods of Creating This Effect
- Large flash and a bang, syncronized perfectly, a small amount of smoke
- Flash eminates from broomstick
- Extremely Expensive
- Only one flash per "loading" of the prop
- Bright flash with smoke
- Zero-cost
- Can syncronize with sound effect to create bang
- Impossible to point, and repeat for each flash (The actors would not be able to hit the exact same spot, every single time)
- Incandescent bulb heat up time doesn't create a quick flash (Think cheesy theatrical/movie lightning)
- Bright Flash
- Low cost (We have a company nearby who rents to DJ's for extremely low prices)
- Floods the entire area
- Fairly hard to syncronize to bang (internal variances in strobe light can cause the bang to happen before or after the flash, ruining the effect.)
- Flash does not eminate from broomstick
- Fairly low cost
- An excuse to use high power LEDs
- Lower voltages keep it safe
- We would need at least 20 LEDs to create a large enough flash, so disguising the flash unit would be hard
- Zero-cost (All parts were found in my basement)
- Bright flash
- An excuse to tear apart a disposable camera and use the high voltage stuff inside (Haven't you ever wondered what was inside one of those things?)
- Easily disguisable (Flash tube is small, and battery pack can be hidden in the tail)
- Multiple flashes can be achieved without having to reload the prop.
- Fairly hard to syncronize to bang.
- Extremely high voltages can injure actors if misused or misbuilt
As such, I decided to go with the Disposable Camera Flash. To combat the cons of this method, I came up with the following solutions.
- Synchronization: To synchronize the flash to a sound effect, we created a two part effect. The first part was a "charge up" sound effect. This lasted about 3 seconds, and was promptly followed by a large bang, with some thunder mixed in. The plan was to fire the sound effect when the witch pointed her broom, and then she would fire the flash right before the bang happened, so they occur simultaneously to the audience.
- Insulation, insulation, insulation. To protect the actors and the techies in charge of preparing the broomstick, I wrapped the PCB for the flash in a layer of Gaff tape, which provided a thick insulating layer, but still provided access to the charge button and battery holder. I also double insulated the connections at the flash tube, with a double layer of shrink tubing, and multiple layers of clear packing tape around the tube. This was a very important step, as the ends of the tube carry 300 volts constantly when the flash is fully charged.
STEP 2: Disclaimers and Safety
I AM NOT RESPONSIBLE IF YOU DO NOT FOLLOW THE INSTRUCTIONS, AND GET BLOWN ON YOUR REAR END. THIS PROJECT INVOLVES EXCESSIVELY LARGE VOLTAGES, AND SHOULD BE HANDLED RESPONSIBLY.
This project is fairly dangerous, and can injure people. Please, be responsible, and be careful. Use common sense.
- ALWAYS TREAT THE DEVICE LIKE IT IS LOADED.
- ALWAYS TAKE THE BATTERY OUT BEFORE WORKING ON THE DEVICE.
- But just because the battery is out does not mean the device is safe to touch. The main capacitor can remain charged for days after the device has been charged up. When I came in one day for a show, I checked the device to make sure that it worked. Before touching it, I made sure to trigger it. And a full 22 hours after being charged, the capacitor had enough power to fire the flash one more time. THIS CAPACITOR IS DANGEROUS. USE CAUTION AROUND IT. Make sure to discharge the capacitor by firing the flash unit (whether it flashes or not) at least 3 times, and then discharge the capacitor by touching the leads with a screwdriver that has an INSULATED handle. This will make sure the board is safe to use.
- The flash tube has a constant 300 volts applied to the ends of the tube whenever the capacitor is charged. If you touch the ends, you will get a shock. And the tube is glass, so be careful with it.
- If you are reading this step, good job. You can skip step 3, and move on to step 4.
- This Instructable assumes that you are fairly well versed in electronics, and is NOT RECOMMENDED for beginners. I REPEAT: If you are looking for a beginner project, this is not the project you are looking for.
Camera selection: I used a Kodak PowerFlash Disposable Camera. This camera has an Auto-Recharge function, which causes the flash to recharge once it is discharged. Some cameras do not have this feature, and need to be recharged after firing the flash. I would recommend a camera with the auto-recharge feature.
STEP 3: Go Back and Read the Disclaimer Again...
Yes, I am going to have to run through this, but as this project has the potential to cause bodily harm if misused, I feel obligated to state the following.
- If you are reading this step, good job. You can skip step 3, and move on to step 4. (See, there is the instruction...)
STEP 4: Disassembly: Step 1
STEP 5: Disassembly: Step 2
STEP 6: Disassembly: Step 3
But first, take a look at the ingenuity of the trigger for the flash. To ensure that the flash occurs when the shutter is open, the manufacturers of the camera made the shutter the trigger for the flash. When the shutter opens, it contacts a rail at the bottom, completing the circuit, and triggering the flash.
STEP 7: Disassembly: Step 4
STEP 8: Electronics: Preview
Several things to notice:
- The two trigger bars: We will be modifying those to act as the trigger for the flash.
- The charge button: We can either leave the charge button, or add a second switch somewhere else, to allow the flash to be charged remotely. For our production, we had enough time to charge up the unit before the Witch's entrance to prevent us from needing to remote the charge button.
- The battery holder: For our production, we used a rubber band to hold the battery in place, but it tended to rattle loose. I would recommend adding a single AA holder instead of the current holder.
- The Flash Tube: The business end of the flash, it consists of three contacts. There is a terminal on each side of the flash tube, and then a single contact near the center of the tube to draw the arc across. Once the tube is charged, applying 300 volts to the center contact will draw the arc across, causing the flash.
STEP 9: Electronics: Step 1
The pictures correspond to the steps below.
- Gather your tools. Then take off:
- One of the trigger bars.
- The other trigger bar.
- The flash tube.
- The flash tube supports
- The flash reflector. This pushed off easily once the flash tube was removed.
STEP 10: Electronics: Step 2
- Let's work on the flash tube.
- First, solder on two leads, of the length that you desire. For this project, I am only going to be moving things out about 4 inches, but I have gotten the flash to go off when the bulb is 3 feet out.
- Then, cut enough heat shrink to cover the leads and a good amount of the wire.
- Shrink the shrink tubing.
- Now, we need to create the trigger lead. Cut another lead, preferably out of a different colored wire, and strip the end down enough to allow you to make a complete ring around the flash tube.
- Solder the trigger lead into a loop around the flash bulb.
- Move the ring to one end, and bend the ring to follow the other lead. This is just one reason why the shrink tubing is important...
- Cover the entire assembly with either clear shrink tubing, or (less preferred) use clear packing tape. I didn't have clear shrink tubing of the correct gauge, so I had to settle with clear packing tape.
- Solder the entire assembly to the pads on the PCB. Make sure to attach the leads to the correct pads. If you do this incorrectly, you could have a very dangerous situation.
STEP 11: Electronics: Step 3
- Find a switch. It needs to be Momentary and Normally Open (NO). Other than that, be creative. And, wire on another set of leads.
- Solder the leads to the PCB. My board had two pads for one of the trigger bars. Obviously, if you wire them up to those pads, the flash will not work...
STEP 12: Test!
Carefully insert the battery, and push the charge button WITH A NON CONDUCTING TOOL. I am not sure how much voltage runs through the charge button, but to be safe, push it with a tool... Wait a second, and then release the switch. Hopefully, you should be able to hear the whine of the flash charging up. If not, don't fret, it might be just inaudible.
Then, the moment of truth. Press the trigger switch, and the flash should fire! If it doesn't check your connections, and make sure everything is correct. Make sure the battery is in the correct direction.
Wait about 3 seconds, and then push the trigger again. The flash should fire again.
Pull the battery, and fire the flash twice. This should almost fully discharge the capacitor, and then discharge it the rest of the way, using a tool with a non-conducting handle. THIS IS CRITICAL. Notice the second picture. Even though the battery has been pulled, the capacitor still has enough power to light the neon bulb, and can still fire the flash again.
STEP 13: Insulate
STEP 14: Disguise in the Prop
Be creative! Expose the wiring if it works, hide the wire in pipe, hide it in a plant, the possibilities are endless!
STEP 15: Use
Once the actor needs to fire the unit, they should be able to just push the trigger switch, and the flash will fire. They can then wait 3 seconds, and the flash should have recharged, and can be fired again.
Once the actor gets offstage, pull the battery, and fire the prop until it will not fire anymore. It should now be safe(r) to handle.
STEP 16: Ideas for Improvement
As this is a theatrical prop, there are many ways to improve the effect.
- Better battery holder: For more permanent installations, I recommend replacing the battery holder with one that has a switch.
- Remote the charge button: To allow the actor to charge up the flash themselves, I would recommend attaching another switch that replaces the button on the PCB. This will simplify charging the circuit, and provides a backup.
- Reorient the main capacitor: Every night, I had to repair the capacitor, by bending it back into place. If the location of the battery pack is taller, you can take and reorient the main capacitor upright. This reduces the chance that it will get bent. I considered it, but it wouldn't work in our case.
- Better Case: Please, if you have the time and the option, install it in a plastic case... Please...
- Multiple flashes synced together: By using a Dual pole, single throw (DPST) or a dual pole, dual throw (DPDT) switch, you can synchronize multiple flashes fairly accurately.
27 Comments
thegeeke 11 years ago
1. Position an elipsoidal, ParNel, or Scoop behind the actor (or just to the side) so that they are pointing into the audience. Preferably 2-20 fixtures. Use plenty of haze (preferably haze and not fog). At the correct time, flash your lights behind the actors so that it gives an intense effect towards the audience making them feel like the broomstick was pointed at them. It get's really fun if you can use gels and do different colors.
2. Use as many intelligent lights as possible strobing different colors, positions, and if you have any decent gobos for the effect use gobos as well on the person the broomstick is pointed at. If you do it right, the lights should be only on the person the broomstick is pointed at, and the audience will be so dazled by the sudden lighting that they will not even notice that the broomstick didn't have any effects on it. It takes about an hour to program this sequence and it only lasts for a few seconds, so don't think this is the easy effect. ;)
There are other ways of doing it, but these two (aside from pyrotechnics) are my favorites. Your ible is a fantastic option for groups that have extremely limited resources though! :)
pjensen 11 years ago
In the space we were using, there were 8 old intelligent washes that we could have used to finish up the effect, but they don't produce very much light... I have done something similar to your #1 suggestion before, and it has worked great, but it just wouldn't work in this situation.
In this same show however, I did use a combination of an ellipsoid with a lightning gobo and the intelligents on the scrim to produce a stunning lightning through clouds effect. With everything flying behind the scrim (Remember, this is the Wizard of Oz, specifically the tornado scene...), the effect was perfect.
And second, Thanks!
Who do you do lighting for?
missroberta 5 years ago
pjensen 5 years ago
We didn't want to use smoke effects for the entrance, because we were worried about differentiating the melting from the standard entrance, but you could make a fog-bag for a poofing smoke effect. You will need a large plastic bag. Put the bag offstage with the mouth towards stage. Fill the bag with fog, keeping the mouth fairly closed. Using a foamcore sheet (or just arms spread wide), pushing down on the bag rapidly will create a decent, billowing poof of smoke.
Props Maker 8 years ago
pjensen 8 years ago
It's probably easier if you find someone in your production! You probably have someone in your show (if not in the area) who can spin this up really quick. It took me less than a day to create this, and I was experimenting on the way. Talk to your tech crew, someone is bound to have the tools and expertise to pull this off.
bonanno.mark 10 years ago
Thanks for the help. I will keep you updated!
pjenson - I am trying to re-create this (for the wife's WoO). I am having the devil of a time getting the flash to fire as often as it does when it is on the camera. I checked my voltage across the bulb leads and am getting 300v. I can get the bulb to fire but sometimes it takes 20 to 30 seconds before it will trigger. When I put a VOM on the trigger to ground leads I see that I don't have 300v. Any suggestions on what I am doing wrong?
pjensen 10 years ago
Hmm, the trigger lead will only reach 300 volts when the flash is firing, which is often times too short for a multimeter to register. Does the indicator light turn on right before you can fire it? Or does it come on almost immediately after firing?
You can also measure the battery voltage. If the battery is low, it will take longer to charge. You want a battery with a voltage above 1.4 volts for ideal use. One other test that you can do is measure the voltage across the capacitor after you fire the flash. You should see the voltage slowly rise back up to 300 volts. Once the capacitor reaches around 270 volts, you should be able to trigger the flash. The time it takes for the capacitor to reach 300 volts is the limiting factor in most cases. If you still are having issues, you might have a bad switch.
Also, the brand of camera that you use can affect the charge rate. I used a Kodak Powerflash, but if you have a different camera, it might be slower.
I have a "Max Hold" on my VOM and it USUALLY is fast enough to catch the trigger voltage. When the circuit fires, it USUALLY registers above 300v. When it isn't firing I can actually watch the voltage climb up to the required 300 as I cross the "shutter/fire" leads multiple times.
I tried several batteries (including some Lithium). I never got the same rate of firing that I was able to get off the camera. When the circuit is untouched (still on the camera) I am able to fire every 4 or 5 seconds. Once I removed components from the board.... firing became erratic. All the batteries had a voltage greater than 1.5 (the Lithiums where closer to 1.7).
I measured the voltage at the bulb, that SHOULD have been the same as the capacitor, right? It read 300v.
I have to admit, I thought the problem was first one switch and then another. Finally I just started crossing the leads leading to the switch. At first it seemed to work - then I was back to the erratic behavior.
I will say that I bought several (cheap) cameras and all of them had the issue. As soon as I moved the bulb off of the board, firing would become erratic. Now, that seems to point to my soldering (which I will say is not the best). So I used alligator jumper leads. Same issue.
In the end I gave up and kept all the components on the board (there was a LOT of 4 letter words expelled before I did this). I have soldered the "charge" leads down and actually soldered the leads for the switch directly to the copper tangs that are on the board. At the moment everything is working and I am able to get a good firing rate of every 5 seconds. Of course, this means that I have the entire unit to put at the end of the broom. That is a job for the morning. I am including some pictures of the Frankenstein's Monster that I created. I will post what it looks like in the broom tomorrow.
Thanks!
Aha! I think I found your problem. When you took the bulb off the board, did you move the reflector with it? When the flash fires, the whole reflector gets brought up to 300 volts. There should be a little copper lead which goes in between the board and the reflector, and that needs to be securely attached and have low resistance to the reflector. Alternatively, you can just do what I did, and form it into a loop that fits around the bulb, and ditch the reflector entirely. The catch with that is the loop needs to go around the correct side of the bulb or the flash might not fire.
nbonanno 10 years ago
This looks great and just the kind of thing I need to do in a church production of Wizard of Oz. I assume there was a button the Witch pushed to make the flash...where was it hidden?
Thanks! If you notice the main image, you can see how her hand is positioned right at the base of the broom's bristles. That is where the button is hidden. The bristles had about two inches of extra length above the coil on the broom, so I could tuck the button the coil, and the board underneath the coil. You can see this clearer if you go to step 14, and look at the annotations on the image.
How embarrassing. I had found this front page with a search and didn't realize there were actually steps I could follow! And how nice of you to take the time to show the rest of us how to do this!
Hah! No problem! We all have that one moment of visiting a new website and completely failing at it! Welcome to Instructables!
SelkeyMoonbeam 11 years ago
