Introduction: There's a Frog on Your Head Hat for Kids & Adults
When our daughter was about 5 years old, she drew a picture of the kind of hat that she would like to have. She came up with was this idea of having a frog sitting on top of her head.
I decided to turn it into a real hat that she could wear.
It is knit with bulky yarn, so it knits up quickly so the hat can be made in a day.
The legs and eyes are made using crochet as I could not figure out how to knit these pieces for the hat.
Me, being a big kid, wanted one for myself to wear, so I made one in a larger size to fit my head.
We both get lots of compliments and people smile when they see these frogs sitting on top of our heads.
Step 1: Gather Your Yarn & Tools
This hat is made with bulky weight yarn, so it knits up fast and easy.
I chose gray to make the ribbing on the hat, but you can choose any contrasting color you like.
You will need
- 1 ball (100 grams) bulky green yarn like Berroco Comfort Yarn from Webs
- 1 ball (100 grams) bulky contrasting color yarn like Berroco Comfort Yarn from Webs
- Small amount of 4 ply white yarn for the eyes
- Small about of 4 ply dark color yarn for the centre of the eyes
- Small amount of 4 ply red for the mouth (or use the color of your choice)
- 5 mm (US size 8) (UK size 6) knitting needles
- 4 mm (Us size G/6) (UK size 8) crochet hook
- Darning needle
- Ruler
TIP - check your yarn stash for the small amounts needed for the eyes and mouth.
Step 2: Start at the Top of the Hat
Instructions are for a child's size hat ( 3-10 years) with Adult sizes in brackets
Gauge - 3.5 stitches = 1" on 5 mm needles
TIP - Knit a 1-2" sample of 8 stitches and check your gauge. If you don't have the right number of stitches, either increase or decrease the size of you knitting needles to get the correct gauge.
With green bulky yarn and size 5mm needles, Cast on 8 sts
See Learn to Knit on Instructables for detailed basic how to instructions
Purl 1 row
Knit row, increasing 1 in each stitch = 16 stitches
Purl 1 row
Knit 1, increase 1 in next stitch - repeat to end of row = 24 stitches
Purl 1 row
Knit 2, increase 1 in next stitch - repeat to end of row = 32 stitches
Purl 1 row
Knit 3, increase 1 in next stitch - repeat to end of row = 40 stitches
Purl 1 row
Knit 4, increase 1 in next stitch - repeat to end of row = 48 stitches
Purl 1 row
Knit 5, increase 1 in next stitch - repeat to end of row = 56 stitches
Purl 1 row
Knit 6, increase 1 in next stitch - repeat to end of row= 64 stitches
Knit until piece measures 4 1/2" - child
(Adult Hat start hat following above instructions but add one more increase
Purl 1 row
Knit 7, increase 1 in next stitch - repeat to end of row = 72 stitches
Knit to 5 1/2")
Cut off green yarn and join contrasting color
Knit 1 row of contrasting color
Step 3: Add the Ribbing
Next row - Knit 2, Purl 2 - repeat to end of row
Repeat this row until you have 2 1/2" of ribbing
Cast off loosely leaving 18" of yarn for sewing the seam
TIP - Use a needle 1 mm larger to cast off. This make the cast off loose enough
Step 4: Make the Eyes
Use 4 ply dark yarn and a 4mm crochet hook.
Start with a Magic Circle (or ch 2)
Make 8 sc in circle ( or 8 sc in 2nd chain from the hook)
Join into a circle and cut the yarn
Join white to sc in dark circle
Sc in 1st stitch, ch 1
Repeat around the circle to the last sc
Join and cut yarn, leaving 18" for sewing on the eyes
Step 5: Make the Legs
Make 4 Legs
With bulky green yarn and 4 mm crochet hook,
Ch 13 sts,
Sl st in 2nd chain from hook
Sl st in next 2 chains - makes 1st toe
Chain 4,
Sl st in next 2 chains - makes 2nd toe
Repeat to make 1 more toe
Sc in top of 1st toe
Sc in each of the remaining 9 chain stitches
Tie off yarn leaving 18" to sew the leg on the body
Step 6: Sew on the Legs
Lay the hat flat with seam at the center back of the hat
Sew on 2 back legs as shown in the picture, on either side of the back seam
Gently stretch the ribbing flat as you sew these on
Leave about 1 1/2 inches between legs
Turn the hat to the front
Sew on the 2 front legs as shown in the picture
You are almost done....
Step 7: Sew on the Eyes
Sew on the eyes to the front of the hat as shown in the picture
Embroider mouth
You are now finished
Enjoy having a frog on your head!!
