Introduction: Thermocouple Type K - Arduino ESP32
Intro - ESP 32 microcontroller circuit was set up with a HS711 amplifier to read a thermocouple type K for a reference input from digital thermometer.
  1. 1 - Breadboard
  2. 1 - Thermocouple type K
  3. 1 - HS711 Amplifier
  4. 1 - Arduino ESP 32
  5. 1 - DS18B20 Digital Thermometer
  6. 3 - resistors
  7. 5 - male to female jumper wires
  8. 3 - female to female jumper wires
  9. 1 - USB to ESP 32 connector
  10. 2 - hook up clips (female)
  11. 1 - hook up clip (male)
Step 1: Connect Electronic Technology
From ESP 32
  1. D25 -> SCK on HS711 Amplifier
  2. D26 -> DT on HS711 Amplifier
  3. VIN -> VCC on HS711 Amplifier
  4. GND -> GND on HS711 Amplifier
  5. D27 -> spot A2 on breadboard
  6. GND -> spot A1 on breadboard
  7. 3V3 -> spot A3 on breadboard
From HS711 Amplifier
  1. A+ -> small prong on DS18B20 digital thermometer
  2. A- -> large prong on DS18B20 digital thermometer
  3. E+ -> spot F1 on breadboard
  4. E- -> spot F6 on breadboard
From DS18B20 digital thermometer
  1. Small prong -> F3 on breadboard
On breadboard
  1. GND - spot A1 on breadboard
  2. D27 - spot A2 on breadboard
  3. 3V3 - spot A3 on breadboard
  4. Resistor (23k ohms) B2 to B3
  5. Thermocouple (semi circle outward from rest of connections) in C1, C2, C3
  6. E+ - spot F1 on breadboard
  7. E- - spot F6 on breadboard
  8. Small prong - F3 on breadboard
  9. Resistor (23k ohms) G1 to G3
  10. Resistor (23k ohms) G3 to G6
Step 2: Initialize Arduino ESP 32
Using a USB plugin, plug in the Arduino to your computer.
Initialize the Arduino by downloading Arduino IDE (arduino.cc/en/software)
Under boards manager, search and install Arduino ESP32 Boards by Arduino
Click on ‘select board’, select port, search for and select ‘DOIT ESP32 DEVKIT V1’
Step 3: Run Code
Under Files, Examples, HX711 Arduino Library, HX711_Basic_Example
#include "HX711.h"
// HX711 circuit wiring
const int LOADCELL_DOUT_PIN = 26;
const int LOADCELL_SCK_PIN = 25;
HX711 scale;
const float Vref = 2.0; // Reference voltage in volts
const int gain = 128;  // Gain factor for HX711
const long maxBits = 8388608; // 2^23, the maximum code for 24-bit ADC
void setup() {
 Serial.begin(57600);
 scale.begin(LOADCELL_DOUT_PIN, LOADCELL_SCK_PIN);
void loop() {
 if (scale.is_ready()) {
  long reading = scale.read();
  // Calculate Vtc from the code
  float Vtc = (float(reading) * Vref) / (gain * maxBits);
  // Print raw reading and calculated voltage
  Serial.print("HX711 reading: ");
  Serial.print(reading);
  Serial.print(" => Vtc: ");
  Serial.print(Vtc, 6); // 6 decimal places for precision
  Serial.println(" V");
 } else {
  Serial.println("HX711 not found.");
 delay(1000);
For LOADCELL_DOUT_PIN = 26 and LOADCELL_SCK_PIN = 25
Run code
Step 4: Solve for Voltage of Thermocouple
Update code to find V_tc
V_ref = 2V, gain = 128, 24 bits-sign = 2^23
V_tc = (code x V_ref) / (gain x 2^23)
Add code for solving and press upload
Using Thermocouple Type K reference table, use V_tc to find temperature
