Introduction: Thermostat Lamp
Thermostat lamp is a wall lamp designed for outdoor use. This one is able to change color according to the temperature.
Step 1: Assemble Materials
Material required are:
(x1) arduino uno
(x1) Bread Board
(x1) Temperature sensor
(x12) Jumper wires
(x1) LED strip RGB
(x1) Current transformer
(x1) LED’s connector with arduino (cable)
Step 2: Program
The program will measure the temperature and if the temperature is less or equal than the Minimum Temperature, the LED will turn blue, if the temperature is higher than the Temperature_Minimum value but lower than the Maximum_ Temperature value, the LED will turn green last if the temperature is greater than the Maximum_ Temperature value, the LED will turn red. The temperature value will be displayed on the Serial monitor.
Now is time to code the arduino. For this project this code has been used.
const int LM35 = A0;
const int R=4;
const int G=3;
const int B=2;
const int Temperatura_Minima=65;
const int Temperatura_Maxima=75;
float Temperatura;
void setup () { Serial.begin(9600); //Inicializar puerto serial
pinMode(R,OUTPUT);//Inicializar el pin 4 como salida
pinMode(G,OUTPUT);//Inicializar el pin 3 como salida
pinMode(B,OUTPUT);//Inicializar el pin 2 como salida
digitalWrite(R,LOW);
digitalWrite(G,LOW);
digitalWrite(B,LOW);
void loop() { Temperatura = analogRead(LM35);//Leer la entrada analogica
//Calcular la temperatura
Temperatura = 5.0*Temperatura*100.0/1024.0;
//Mostrar la temperatura en el monitor Serial
Serial.print(Temperatura);
Serial.println(" ºF");
//Codicion para que encienda el led de color Verde
if(Temperatura>Temperatura_Minima&&Temperatura<Temperatura_Maxima) {
Serial.println("Deberia encender verde");
digitalWrite(R,HIGH);
digitalWrite(B,HIGH); }
//Condicion para que encienda el led de color Azul
if(Temperatura<=Temperatura_Minima) {
Serial.println("Deberia encender azul");
digitalWrite(G,HIGH);
digitalWrite(B,LOW); }
//Condicion para que encienda el led de color Rojo
if(Temperatura>=Temperatura_Maxima) {
Serial.println("RED");
delay(500);
