Introduction: This DIY Electronic Device Will Protect Your Home
In this project, I will show you how to build a DIY electronic security device using a DFPlayer Mini MP3 module and a reed switch. This simple circuit can be fixed on any door, and when the door is opened, it will instantly play a warning voice or alarm sound from the DFPlayer Mini.
It’s a low-cost, easy-to-build, and very effective anti-theft solution for homes, shops, and cupboards. With just a few common electronic parts and a 9V battery, you can protect your belongings and add an extra layer of security.
To make it professional and durable, I designed a custom PCB (ordered from PCBWay) and enclosed it in a 3mm acrylic case. The project is compact, portable, and completely customizable — you can even replace the sound file with your own voice or music!
- DFPlayer Mini – MP3 voice module
- Reed Switch – Magnetic door sensor
- AMS1117 (5V) – Voltage regulator
- 9V Battery – Power supply
- BC547 Transistor – Switching transistor
- IN5822 Diode – Reverse polarity protection
- 100µF Capacitor – Power stabilization
- On/Off Switch – To control power
- Speaker – For voice/alarm output
- Jumper Wires – For circuit connections
Step 1: Get the PCB
For this project, I designed a custom PCB to make the circuit neater, stronger, and reliable for real-world use. Instead of messy jumper wires, using a PCB ensures better durability and a professional finish.
✅ Why I Chose PCBWay?
- High-precision manufacturing
- Fast delivery with worldwide shipping
- Low cost (great for students, makers, and pros)
- PCB Assembly service available
- Excellent support and instant online quoting
🧾 Simple Ordering Steps:
- Design your PCB in software (like KiCad, EasyEDA, or Eagle)
- Export your Gerber files
- Go to PCBWay.com
- Upload your Gerber files
- Get an instant quote and place your order
🚀 With PCBWay, your DIY project becomes more professional and reliable!
👉 Order your PCB now at PCBWay.com
📂 (Circuit Diagram and Gerber Files are attached below for easy ordering.)
Step 2: Insert All Components on the PCB
After receiving your PCB from PCBWay, start inserting the components into their respective positions as marked on the PCB.
🔧 Tips for Assembly:
- Begin with small parts first, then move to larger ones.
- Follow the silkscreen labels to avoid mistakes.
- Double-check polarity for parts like capacitors, diodes, and regulator.
- Once all components are placed, solder them securely.
Step 3: Mount the DFPlayer Mini
The DFPlayer Mini is the core of this project — it plays the alarm or voice files when triggered. To use it properly, make sure it is inserted in the correct orientation on the PCB.
📌 DFPlayer Mini Pinout (commonly used pins):
- VCC → +5V power
- GND → Ground
- TX/RX → Serial communication (if using Arduino)
- SPK_1 & SPK_2 → Speaker connection
- DAC_R & DAC_L → Audio out (for amplifier)
- IO1 & IO2 → Standalone trigger pins
👉 For this project, we use SPK_1 & SPK_2 to directly connect the speaker.
Step 4: Soldering & Finishing the PCB
After placing all the components correctly on the PCB:
- Solder Joints – Heat each pad and apply solder so it flows smoothly and makes a shiny joint.
- Cut Excess Leads – Trim the extra legs of components using a cutter. This keeps the PCB flat and neat.
- Clean the PCB – Use a PCB cleaning liquid (IPA – isopropyl alcohol) or flux remover with a small brush/cotton to clean off any flux residue. This prevents corrosion and ensures a professional finish.
⚡ A clean PCB not only looks good but also improves long-term reliability.
Step 5: Add 9V Battery Connector
- Cut two short pieces of thick copper wire.
- Insert them into the marked battery input holes on the PCB (+ and –).
- Solder them firmly from the backside.
- Bend them slightly so the 9V battery clips on tightly.
Step 6: Enclosure With Acrylic Sheet
- Place the PCB on the acrylic sheet and mark its outline.
- Cut the acrylic sheet to the exact PCB size (use a cutter, hacksaw, or laser cutting if available).
- Make 4 pieces – one for the bottom, one for the top, and strips for the sides.
- Apply super glue/Fevikwik around the edges and fix the acrylic pieces together.
- Ensure all sides are sealed properly so the PCB stays secure inside.
✨ The acrylic cover not only protects the circuit from dust and damage but also gives it a professional and transparent look.
Step 7: Make Holes in Acrylic for Connections
- Mark the positions on the acrylic sheet where the speaker wires, power wires, and switch will come out.
- Use a 3mm–5mm drill bit (or a soldering iron tip carefully, if no drill is available) to make neat holes.
- Pass the speaker wires, 9V battery wires, and On/Off switch leads through these holes.
- After inserting the wires, fix the top acrylic sheet with glue.
⚡ This ensures your project is enclosed safely, while still allowing easy access to connections.
Step 8: Prepare the Memory Card
- Insert the microSD card into a card reader and plug it into your PC.
- Format the card as FAT32 (quick format is fine).
- Choose any song, music, or alarm sound you want to play.
- Rename the file to 001.mp3 (the DFPlayer plays files in order).
- Copy and paste the file into the root directory of the memory card (not inside any folder).
- Safely eject the card and insert it into the DFPlayer Mini slot.
- Connect speaker +ve & -ve
⚡ Now, when the reed switch triggers, the DFPlayer will play your custom sound. You can change it anytime by replacing the file.
Step 9: Power Up With 9V Battery
- Connect a 9V battery to the copper wire terminals (or connector) provided on the PCB.
- Use a good quality 9V rechargeable or branded battery – cheap ones get weak very quickly and won’t give proper backup.
- Turn the On/Off switch ON to power the circuit.
- The DFPlayer Mini will now be ready to play the audio whenever the reed switch is triggered.
⚡ Using a strong battery ensures longer backup and reliable performance for your alarm device.
Step 10: Installation & Testing
🔧 Installation:
- Fix the PCB (inside acrylic case) on the door frame using screws.
- On the opposite side of the door, fix a small magnet aligned with the reed switch.
- When the door is closed, the reed switch stays OFF.
- When the door is opened, the reed switch activates and the DFPlayer Mini plays the alarm sound stored on the memory card.
🎥 Demo:
Switch ON the power and open the door to test — you’ll hear your custom voice or alarm sound (001.mp3) play instantly.
