Introduction: This Oxy-fuel Cutter Cuts Metal in 1 Second / Tutorials
Hey friends! In this Instructables, I'll show you how to make a powerful torch using a Brown gas generator. This device can cut through metal in just one second! I'll guide you through the entire assembly process, step by step.
I've included links in the description for the tools and materials you'll need to make the project easy and accessible.
Don't miss this video on my channel — make sure to subscribe! Leave a comment, and I'll be happy to answer your questions and hear your thoughts!
To build this powerful torch, you'll need quite a few components. Here's a quick list of some of them:
- 3.5 mm mini jack
- Three AAA batteries
- Needle from a medical syringe
- High-pressure tubing purchased from JLCMC
- High-pressure valve purchased from JLCMC
- Y-shaped high-pressure fitting purchased from JLCMC
- And much more, all demonstrated in the video!
To keep things simple, I've left all detailed explanations in the video on my channel. Make sure to check it out and subscribe! https://www.youtube.com/watch?v=wqRBASCawXA
For this project, I used components ordered from JLCMC — a fantastic website with low prices and high-quality products. You can order parts for small DIY projects as well as for factories and industrial workshops. I also have an exclusive discount available for my subscribers!
Register&Enjoy $19 coupons at JLCMC https://jlcmc.com/?from=RUHNOV1 #JLCMC
Step 1: Torch Assembly: Step by Step
1️⃣ Disassembling the Mini Jack:
Carefully take apart the mini jack, keeping only the metal casing.
2️⃣ Preparing the Contact:
Extract the positive contact from the battery and place it inside the mini jack casing for a secure connection.
3️⃣ Installing the Needle:
Insert the needle from the medical syringe into the high-pressure valve. Carefully pass it through the pre-prepared section of the torch structure. This step ensures precise and stable gas flow.
Step 2: Mounting and Connecting Torch Components
1️⃣ Installing Motors:
Secure the motors to the top of the plastic container. This is essential for creating a stable airflow and ensuring proper device operation.
2️⃣ Creating Connections:
Assemble multiple high-pressure hose fittings to establish a reliable system connection.
3️⃣ Setting Up Quartz Sprayers:
Connect two quartz sprayers to ensure an even distribution of the gas mixture for efficient and safe cutting.
Step 3: Final Torch Assembly Stage
1️⃣ Connector Installation:
Install the connector to power the two motors with a 9-volt battery, ensuring stable energy supply for the system.
2️⃣ Hose Connections:
Carefully connect all hoses to maintain a tight and secure setup.
3️⃣ Liquid Filling:
Fill two containers with liquid. One acts as a water trap to prevent flame backflow into the system, an essential safety feature.
Step 4: Torch Features and Benefits
This torch offers numerous advantages:
🔥 Effortlessly cuts metal up to 3 mm thick.
🔥 Can heat and melt metals like gold and silver, perfect for casting or soldering.
🔥 Economical and achieves extremely high temperatures.
🔥 The mini-jack housing remains cool even during extended use, demonstrating the correct setup and preventing unnecessary overheating.
If you have any questions or need clarification, check out my YouTube channel, where I'll be happy to help and provide more details! https://www.youtube.com/@romanursuhack
