Introduction: Three Push ON – Push OFF Latching Circuits
A flip-flop or latch is a circuit that has two stable states and can be used to store state information. The circuit can be made to change state by applying a signal (in this case, by pushing a button).
Here, I will show you three different ways to make latching circuits:
- Using 555 Timer IC
- Using Transistors
- Two Switches
I will also show you how to toggle between two outputs (by using transistors), using a single push button switch.
Pushing the push button once turns ON the output (LED), and pushing it again turns it OFF.
You can also use separate Push Buttons to switch ON and OFF the load.
Step 1: Circuit Diagram
These are the circuit diagrams for:
- 555 Timer IC
- Toggle Switch
- Transistors
- Two Switches
Step 2: Components
These are the Components Required for:
1. Using 555 Timer IC
• 555 Timer IC
• Push Button Switch
• Resistors: 100K, 10K (2), 330Ω
• Capacitor: 1 μF
• LED
2. Using Transistors
• Transistors: BC547 (2), BC557
• Resistors: 1M, 470K, 220K (2), 100K (2), 10K, 1K, 330 Ω
• Capacitor: 1 μF
• LED
3. Using Two Switches
• Transistors: BC547, BC557
• Push Button Switches (2)
• Resistors: 10K, 1K (3), 330 Ω
• LED
Other Requirements:
• Battery: 9V and battery clip
• Breadboard
• Breadboard Connectors
Step 3: Step-by-step Tutorial
This video shows you step-by-step, how to build all these circuits.
