Introduction: Three Ways to Get Safe Drinking Water From Snow
One of the things I like about winter in Canada is that we get LOTS of snow! This means that drinking water is abundant, you only need to know how to process it out of the snow we get.
I created a YouTube video here:And I also posted this on my blog here: http://muskrat-survival.blogspot.ca/
As many of you are aware, a handful of fresh snow is mostly made up of air. That's right, a little bit of water and a lot of air. If you were to fill a pot with snow and set it on a fire, you would likely scorch the bottom of your pot.
The following are three ways that I like to use to melt snow into drinking water:
Step 1: Body Heat
Step 2: Warmth of a Fire
If you don't have a metal container to slowly melt snow near a fire, you can make do with a bandana and a cup or other container. Simply open the bandana flat then fill the middle of it with clean snow. Tie or pin the four corners of the bandana so it holds the large snowball. Now, using a sturdy branch, suspend the bandana near the fire. Soon the heat of the fire will start melting the snow. Before too long, the large snow ball will start dripping through the bandana. Use a cup or other container to catch the dripping water. This method works well basically unattended. You can go about your business doing other things and just checking back from time to time to make sure your container is still catching the drips and not overflowing.
Step 3: Solar Power
Putting snow on a black garbage bag (a.k.a. drum liner) in the bright sun will melt the snow to give you drinking water, but then it's difficult to get that water into a container. Because of this difficulty, I didn't add it to my video. Then my brother John told me about a simple improvement on this method. By putting the clean snow in a clear zip-loc bag on top of the black plastic solar collector, all your drinking water is conveniently made inside the easy-to-handle zip-loc bag! BRILLIANT !! So this method works if you're camped in a bright sunny location for a while and if it isn't so cold to re-freeze the water as it melts.
If this interests you, consider visiting my YouTube Channel at https://www.youtube.com/MuskratSurvival
I have over 75 videos in my Muskrat Survival Series.
My blog at http://muskrat-survival.blogspot.ca has other survival topics as well.
