Introduction: Thrift Store Bottle Jack
I found an old bottle jack at a thrift store for a few bucks, at a glance, it was non-functional and would just bounce up and down. In the current state, it's unusable and potentially dangerous.
I hate seeing old tools get thrown out when they can be easily fixed and I'm a firm believer in 'fix, not replace'
- A busted old bottle jack
- Transmission Oil (or jack oil if you have it)
- Kerosean
- Wire brush
- Paint
- Paint stripper
- Brake Cleaner or other degreaser
Step 1: Drain & Flush
The first step is to remove the little rubber plug and drain the old oil out. This jack was missing a lot of oil and what was in it was pretty dirty.
I like to give the jack a flush of kerosene at this point to purge any remaining oil from the jack.
Step 2: Disassemble & Clean
I then completely disassembled the rest of the jack and gave everything a good wash with kerosene. While it's not necessary I stripped the old paint off and gave everything a final clean with some brake cleaner.
Step 3: Prep & Paint
I then used some masking tape to cover the parts of the jack that I didn't want to paint. Now give everything a couple of coats of spray paint and once it's dry remove the masking tape.
I let everything cure for a few days so it can harden a bit more.
Step 4: Reassemble & Prime
You can now reassemble the jack, use a small amount of oil on all the seals and then tighten everything down.
Now for the most important part use a syringe to fill the jack with oil. You need to prime the jack by pumping it a few times and then topping off the oil again. Once you have pumped it a few times back off the release valve and while it's open pump it a few more times. The jack should be fully primed now, give it a final top off of oil and insert the rubber plug.
Note: If you have jack oil use that, otherwise transmission oil will work fine.
Step 5: Clean & Test
Now give the jack a wipe down to remove any oil you spilt and you are ready to test the jack. When using a jack make sure to operate it safely, never go under a load that is held up solely by a jack, be sure to use axle stands or some other kind of block.
You can now see the jack operates correctly. I now have a dirt cheap Bottle Jack and saved some waste from the landfill.
