Introduction: Thrustmaster T. Flight Rudder Pedal Lock for Sim Driving/Racing
This tutorial is for the Thrustmaster T.Flight Rudder Pedal system. This very reversible mod makes it so you can lock the pedals from sliding forward and back so you can enjoy using them as racing pedals for your favorite racing sim,or other driving games like American Truck Simulator, and BeamNG.Drive. This process will take less than 5 minutes to complete. Enjoy!
Step one. Flip over your pedal system and look for the smaller of the two doors. Locate the door in the picture and unscrew the single Phillips head screw.
Step two. Remove the cover.
Step 3. Place a small wire tie (Zip Tie) where you see mine in the photo. You can snip the excess or just tuck the remaining part of the tie into the cavity and then reinstall the door, screw, and place your pedals in a comfortable spot on the floor.
Step 4. Before you enter your game, locate the USB converter that came with your pedal system, and make sure to move the switch on the side of that unit to the Car logo. That's it, you are done! Enjoy racing/driving games, and don't forget to setup your pedals in the game so they will work as accelerator and brake pedals. A helpful hint, Press the pedals slowly just in case your game collects data at a slower rate than your foot speed. It will help a lot with calibration. To undo it, simply follow these steps in reverse and snip the wire tie with a pair of cutters making sure to not damage the spring or the plastic ends the spring attaches to. I hope you found this Instructable helpful and if you did, please tell your favorite gaming community that Violational from Vio's Fun House Gaming Community helped you out. Have a great day!
Small Wire Tie (Zip Tie) Available at any store that sells hardware/electrical items. You can find them at any home center, Walmart, and Harbor Freight Tools to name a few,
Standard Phillips Screwdriver also available at the locations above.
Scissors, diagonal cutter, fingernail clipper to snip the excess tie material and to remove the tie completely to undo the mod.
Step 1: Thrustmaster T. Flight Rudder Pedal Lock for Sim Driving/Racing Step 1
Step 1. Flip your T.Flight pedal system over and locate the smaller of the 2 doors on the unit and grab your Phillips screwdriver, then proceed to step 2.
Step 2: Thrustmaster T. Flight Rudder Pedal Lock for Sim Driving/Racing Step 2
Step 2. Unscrew that single screw.
Step 3: Thrustmaster T. Flight Rudder Pedal Lock for Sim Driving/Racing Step 3
Step 4: Thrustmaster T. Flight Rudder Pedal Lock for Sim Driving/Racing Step 4
Step 4.
Step 5: Thrustmaster T. Flight Rudder Pedal Lock for Sim Driving/Racing Step 5
Final step, 5. Before you enter your game, locate your USB converter that came with your pedal system, and make sure to move the switch to the Car logo.
That's it, you are done! Enjoy racing/driving games, and don't forget to setup your pedals in your game so they will work as accelerator and brake pedals. A helpful hint, Press the pedals slowly just in case your game collects data at a slower rate than your foot speed. It will help a lot with calibration. To undo it, simply follow these steps in reverse and snip the wire tie with a pair of cutter making sure to not damage the spring or the plastic ends the spring attaches to. I hope you found this Instructable helpful and if you did, please tell your favorite gaming community that Violational from Vio's Fun House Gaming Community helped you out. Have a great day!
