Introduction: Thunder Tiger Ghost REVIEW
About: The Drone or Quad are also called Quadrocopter, Quadricopter, Quad Rotor or Drone. They all belong to the multi rotors RC category. A Quad have four propellers arranged in across type configuration. The …
Thunder Tiger Ghost: Enlarged frame space provides abundant assembly space for electron systems and easier to install various auxiliary equipment required for aerial photography; Intelligent power display system on the surface provides battery capacity check and anti-spark design; Can use either proprietary battery or use standard Li-po batteries; Build-in “Follow Me” function let the Pilot Drone can Follow him/her to everywhere; Retractable Landing Skids provide better view of the camera lens (360 Degrees); Diagonal distance: 450 millimeters; Frame weight (motor, esc, props): 1.45 Kg; Motor stator size: 28.0 x 14.0 mm; Motor KV: 450 rpm/V; ESC current: 30 A; ESC voltage: 6S Li-po; Propeller size: 11” (27.9 cm); Battery compartment capacity: 6S Li-po (2 x 4000mAh); Takeoff weight: 2.15Kg (using 6S/6000mAh proprietary battery); Max hover time: about 25 minutes (6S/6000mAh); QuadsForFun Official Website: http://quadsforfun.wix.com/quadsforfun; Thunder Tiger Ghost:
Enlarged frame space provides abundant assembly space for electron systems and easier to install various auxiliary equipment required for aerial photography; Intelligent power display system on the surface provides battery capacity check and anti-spark design; Can use either proprietary battery or use standard Li-po batteries; Build-in “Follow Me” function let the Pilot Drone can Follow him/her to everywhere; Retractable Landing Skids Provide better view of the camera lens (360 Degrees); Diagonal distance: 450 millimeters; Frame weight (motor, esc, props): 1.45 Kg; Motor stator size: 28.0 x 14.0 mm; Motor KV: 450 rpm/V; ESC current: 30 A; ESC voltage: 6S Li-po; Propeller size: 11” (27.9 cm); Battery compartment capacity: 6S Li-po (2 x 4000mAh); Takeoff weight: 2.15Kg (using 6S/6000mAh proprietary battery); Max hover time: about 25 minutes (6S/6000mAh); QuadsForFun
Official Website: http://quadsforfun.wix.com/quadsforfun; 01 - ANTENNA COMPASS: Ensure the better calibration, the Compass of the Drone is separated due to sensitive to EMI (Electromagnectic Interference);02 -
INTELLIGENT POWER DISPLAY SYSTEM: After inserting the battery cartridge, the Pilot can check out the battery capacity (level) from the LEDs circle display; 03 - REMOVABLE BATTERY CARTRIDGE: The Thunder Tiger Ghost uses a 6S, 22.2 volts, 6000 mAh, Li-po flat pack battery. It’s possible to use 2S or 3S rechargeable standard Li-po batteries as an alternative; 04 - LANDING GEAR: Retractable landing gears provide better view of the Camera lens. No barriers for the in-flight videos and pictures. A 360º Field of Aerial View; Morpheus H3D-360 Features: New designed brushless gimbal for GoPro Hero3/3+; Adopt special slip ring components; The third shaft can be 360 degrees of unlimited rotation; Provide Chase Head and Lock mode pointing the camera towards front side by clicking just one button; The Gimbal uses separated position sensors to avoid cumulative error for the chase head mode; The three axis (Tilt, Roll, Pan) can be controlled independently; Increased rate of 5200 Hz prove a delicate stabilizing effect; 5 volts power supply system and power consumption of 500ma; WIFI COMMUNICATION:The Thunder Tiger GHOST comes with a professional WIFI module, which can connect with your smart device. The TTRobotix APP provides to the Pilot detailed overview of status such as location, battery
capacity, GPS and much more. The WIFI is built-in two communication modes (Router or PP modes). The user can choose the mode depending on his/her favorite method which can fly with no need router, greatly bring convenience to out-space flight; COMMANDER TRANSMITTER: Equipped with 2.4GHz and 9 channels - sticks for throttle, aileron, elevator, and rudder; and switches for changing flight mode (manual, GPS, automatically landing), folding the landing skids, and changing Mode 1 / Mode 2.
