Introduction: Tic-Tac USBtinyISP Programmer
Frankly, I didn't even expect it to work so didn't take any photographs. I recently decided to make it again with a few improvements(notice the old orange one has the top backwards) and document it for Instructables. You have to make one of these if you:
- want to use bare-bones super-cheap arduinos in your projects
- want to burn bootloader to a blank AVR for your Arduino
- love working with AVRs
- are thinking of buying a programmer
Edit: Modified board so resonator can also be used for timing! If using crystal, middle pin for resonator can be ignored. If using resonator, no need to solder capacitors C1 and C2.
Step 1: Chicken-egg Downloads
The chicken-n-egg situation while working with microcontrollers is that you need to get your program in a microcontroller to program another microcontroller. I know that's whacky but it's only one-time. There are some ways which I'm listing below. You only need one:
- a computer with parallel(or serial) port. The best instructable for a very simple parallel port programmer.
- an ATtiny2313 IC pre-programmed with USBtinyISP code (you can buy it from adafruit)
- a friend who has an AVR programmer(you only need to beg/borrow/steal it for a few minutes)
- an Arduino used as ArduinoISP. You can check this tutorial for ATtiny2313.
I will be using the earlier version of USBtinyISP I made. I had used a parallel programmer to program it's ATtiny2313. You only need a few minutes to upload the USBtinyISP code onto your ATtiny2313, so you can get someone's help who has a PC with parallel port/serial port/AVR programmer/Arduino.
If you're going to someone's place to get ATtiny2313 programmed, remember to download and keep these files in a pendrive:
- Get the USBtinyISP firmware from ladyada's USBtinyISP download page. Download the v1.0 firmware(look for the link at bottom of page: "Zip with all v1.0 firmware files").
- While you are there, you will also need to download USBtinyISP driver according to your computer.
- Download WinAVR. This installs avrdude used to program AVRs.
To use, install all that you've downloaded and extract the firmware zip file to a convenient location.
Step 2: Stuff You Need
- ATtiny2313 x1
- 20-pin DIP IC holder x1
- USB type-B female jack x1
- USB type-B cable x1
- Crystal 12 MHz x1
- Zener Diode 3v6 x2 (3v3 will work too)
- 27-68 ohm resistor x2 (I used 33 ohm)
- 1.5K ohm resistor x5
- 10K ohm resistor x1
- 0.1uF ceramic capacitor x1 (cap. code: 104)
- 12-22pF ceramic capacitor x2 (I used 15 ohm; Cap. code is same as value)
- 100uF 25V electrolytic capacitor x1
- Green LED 3mm x1
- Red LED 3mm x1
- Male header
- Ribbon cable
- 6 pin ICSP header x2
- Female header (optional)
Tools required:
- Cutter/blade
- Plier
- Soldering iron + solder
- Single sided copper clad board
- Etchant
- Drill
- Sandpaper
- Double sided copper clad board(optional)
Rest of the stuff needed depends on your PCB fabrication method. I use toner-transfer so I need clothes-iron, glossy paper, laser printer etc.
And last but not least, TIC-TAC!
Step 3: Etch That PCB
Recipe for PCB fabrication:
- Select only the 16 Bottom, 17 Pads, 18 Vias, 20 Dimension and 45 Holes for viewing. Hit Ratnest.
- Click on print. Check Black and Solid and uncheck Mirror options. Set scale to 1.
- Print the circuit on a glossy paper(preferably photo-paper) using a laser printer.
- Cut a piece of copper board slightly bigger than the printout by scoring with a cutter and snapping.
- Use scotch-brite to vigorously scrub the copper board with water.
- Wipe with a clean cloth and do not touch the surface.
- Iron the circuit printed onto glossy paper.
- Dunk the hot PCB in water. Let the paper soften for 5 minutes. Peel away paper and rub away the sticking paper with a toothbrush.
- Dunk the circuit into your favorite etchant. I like hydrocholic acid+hydrogen peroxide. While you're waiting for circuit to be etched, pop a few tic-tacs.
- After all the unwanted copper is etched away, wash PCB and dip it in acetone(aka nail-polish remover) for a while. Pop some more of those tasty mints. Use scotch-brite to scrub away all the toner ink.
- Ta-da! Shiny PCB is served along with fresh minty breath.
Step 4: Drilling, Sanding and Silkscreening
Now cut off the excess board material from the sides and sand the edges. I also made little grooves for the USB jack's claw-like thingies to sink into. Keep popping tic-tacs throughout this step. It will help you get through the tedious drilling/sanding while increasing concentration and skill(not scientifically proven).
Silkscreen is the outline of components and neat descriptive labels on top of the PCB. Since this is a single sided board, I pasted a printout on the top side of the board. It got blotched and soggy after I cleaned the bottom side with rubbing alcohol but that was just my stupidity. You can also iron the silkscreen the same way as toner-transfer method.
Just select 20 Dimension, 21 tPlace and 51 tDocu layers and print. Cut and paste it but use glue sparsely else it will plug your laboriously drilled holes. If you are using toner transfer to apply silkscreen, leave out 51 tDocu layer and check Mirror option while printing.
Step 5: Program ATtiny2313
Now let's burn the firmware onto ATtiny2313:
- Open command prompt and navigate to the location where you extracted USBtinyISP firmware and go to spi folder in it.
- Type:
avrdude -p attiny2313 -c usbtiny
Replace usbtiny with your programmer's name. List of programmers can be generated using: avrdude -c ?
You should get output-1(lablled in image) which means everything is working fine. If you are getting error like Output-3 in 2nd image, check wire connections again. - Set the fuse:
avrdude -p attiny2313 -c usbtiny -b 19200 -U hfuse:w:0xdf:m -U lfuse:w:0xef:m
You should see something like Output-2. - Run the command in step-1 once more. You should get an error as in Output-3. This is because you have set the fuse to run off external 12 MHz crystal. Connect crystal across XTAL pins(pins 4 & 5) and connect both pins to ground via 22pF ceramic capacitors. Try again. The error should go away like in Output-4.
- Time to burn the firmware:
avrdude -p attiny2313 -c usbtiny -B 1 -U flash:w:main.hex -b 19200
This should also end successfully. If not, did you have a button connected to RST and did you press it?
Step 6: Soldering
Start soldering the IC holder pins first. Then solder everything else except ICSP pins, electrolytic capacitor, male jumper header and USB jack.
Step 7: Soldering Electrolytic Capacitor
Solder it in place keeping the polarity in mind, but keep a few mm of leads separating the capacitor from board. Now bend it into a horizontal position. Don't worry if you kept the leads a bit too long and it ends up resting on a pillow of the adjoining resistor, instead of being flush against the board. You just need to make sure that it is low enough to fit in the box.
Step 8: Soldering Male Headers
This easily accessible jumper option is available so that you can power the AVR IC you are programming with USB power supply. Connecting a jumper means target IC will be delivered USB 5V. Removing it will cut it off. Never have a jumper on this if you are powering your AVR with some other source. Clashing power supplies are not good for your AVR and programmer.
Also, if you have a 6 pin ICSP header or IDC cable(cable with ICSP headers pre-connected with ribbon cable), then solder 3x2 male headers in the holes labelled ISP. I couldn't find any of them in local stores, so I made a small hack to replace the cable. If you follow in my footsteps, do leave the ISP holes as is for now.
Solder the USB jack as well and bend those claws flat against the bottom of board.
Step 9: Fitting USB Jack in Top Lid
Step 10: Making Makeshift IDC Cable
If you are following my method, then cut off a 6 wire ribbon cable choosing the edge with stripe. Then I stripped and twisted the wire ends and arranged the wires in 3x2 kind of formation. Every alternate wire was on kept on the same side. This then went into the ISP 3x2 holes in the PCB with the pink striped wire going into the pin with the dot(MISO) and soldered. Keep it like this if you are only going to use it on breadboard. But if you want to use ICSP headers on boards like Arduino, then read on. Also, now is a good time to test whether this is working or not.
If it's working fine, cut a slit at the bottom of your recently-emptied tic-tac box and thread the unsoldered end of the ribbon cable through it. Take the mini tic-tac box and cut a slit in it's top cap and a pretty big one at the bottom. Thread the ribbon cable through the top and out of the bottom.
Step 11: Making ICSP Connector
First solder the 6 vias in the PCB which are providing connection between top and bottom layers. Put a thin bare wire through the vias, solder it at both ends and snip off the excess wire.
Cut off 2 3-pin female headers and stick them together so they form a 3x2 female connector. Now place it on top side and solder it's pins on the bottom side. Finally, bring the wires from ribbon cable emerging from the bottom of mini tic-tac and solder them the same way they went into the main board. Insert the pink striped wire into the hole with the dot(MISO) and the next one in VCC, then SCK and so on.
Notice this is a mirror image of the layout of these pins in the main board. This is because these female headers will connect to male headers on board and need to be mirrored so they align properly.
Just glue the ISCP connector PCB to the bottom of mini-tic-tac box and we're done!
Step 12: Program Away!
You can see a close-up of the old and new version's ICSP connectors. The old one was compact but the header was on the bottom of the big tic-tac box and so the PCB couldn't be slid out for repairs without snipping the wires connecting header with board ISP pins. Also, the big enclosure would sometimes not let the male and female headers to interact properly due to tall vertical components on some boards. The whole weight of the programmer also bore down on the connector and slight movement of USB wire caused it to jiggle.
Try it out and program arduino codes onto stand-alone AVR ICs using this to make cheap and simple bare-bones Arduinos for your projects. Or you can put a fresh AVR into your Arduino and program it using Arduino's built in ICSP headers with this. Have fun programming!
Thanks to catlinsdad for motivating me to make my first Instructable...
If you liked this, please vote for the UP contest.
