Introduction: Tie Loads to Car Roofs by Making Temporary Anchors
This is for cars with no racks on the car roof and with at least 4 doors
When there are places to tie the ropes to, or to hook the bungee cords to , then it is easy to tie loads to car roofs with ropes or bungee cords
The places to tie the ropes, or hook the bungee cords , are w called anchor points.
Here is how to make these temporary anchor points
The use of a ratchet strap is also most highly recommended.
The use of a rubbery roof pad is also highly recomended
Step 1: Materials
There are several materials that can be used for anchors.
The materials have to be strong and thin.
For my vehicle, I would consider strong as having a working load of 75 pounds or more
I would consider thin to be less than 3/8 inches thick.
Although I will illustrate the procedure with nylon military belts ( straps)
Other materials could have been used.
For instance:
Cable Ties ( Zip Ties)
550 paracord
Electrical cord
Other thin wirres or cables
Luggage straps
Leather belts
Step 2: Tie Straps Around Center Posts of Cars
Tie the straps loosely around the centerposts.
Turn the knots inside the car and close the doors
The knot used to tie the ends of the strap together is called a "water knot"
Many sites on the web show how to tie a water knot.
If tying this knot is a problem, then consider using cable ties or paracord or a wire or cable.
Small clamps will bind cables and can be obtained at the Ace Hardware store.
Step 3: Turn Strap to Inside of Car and Close Door
Inside View of Knot
Step 4: Outside View
View From Outside
Step 5: Anchor Points on Both Sides
This is how the car looks with anchor points on both sides
Step 6: Loaded Car
Here is a picture of a car loaded using the anchors
Step 7: Option: Instead of Straps, Use Long Cable Ties
One easy way tpo majke anchors is to use a long ( 18-36" cable strap
These are also known as Zip ties
They are thin and strong.
They can cost from 0.30 - 1.00 each and are not re-useable
But they are easy.
Step 8: Details of Cord Tied to Anchors
The cord is ttied to anchor using a knot called
"Round Turn and Two Half Hitches"
Step 9: Two Ropes and Bungee Attached to Anchor
Here the anchor is used to secure two ropes and a bungee
One rope is going toward the front of the load
The other rope is going to the back
The bungee cord us going ovetr the load.
Step 10: About Ratchet Straps
Note that the strap over the load ( step 6 ) is not a bungee cord, it is a ratchet strap.
Here are photos of the ratchet strap and how the strap appears in the car.
Various places on the web show how to use a ratchet strap.
The ratchet strap is good fior applying downward pressure on the load
Step 11: About the Roof Pad
A rubbery roof pad, ( see step 6) tucked under at tghe front and back
does all these things:
Protects the roof
Adds friction so the items don't slide
Improves air flow around the load
Keeps the load from shifting front and back
2 Comments
9 years ago on Introduction
Great ideas! One thing that should be mentioned, during a heavy rain the "anchor" could cause water to be diverted inside the car.
But for dry weather, a perfect solution!
Excellent ideas here!
thank you!
