Introduction: Time Capsule
Make a simple wooden time capsule with the laser cutter
Step 1: Have an Idea of What You Would Like to Use the Box For.
You can want to sketch this out. So you can brainstorm and save time later.
This is what my sketched look like above. I had to do my sketched three times. So do not give up!
Step 2: Measure
Get a ruler and measure everything out. I recommend making a prototype.
Measure your length, width, and hight.
Step 3: Make Your Blue Prints
Go to the website https://boxdesigner.connectionlab.org/
Put all your measurements in the box designer.
Do not forget to measure your material thickness.
Step 4: Save As a "PDF"
Click the "Design it!' button to save it.
Step 5: Open Https://gravit.io
Click " Got it, go to designer"
Step 6: File
In the top left corner
Step 7: Import, Place Image
Step 8: Click Your File
Step 9: Adjust If Need
If you need to delete some lines add text to do it now
I did not for this project
Step 10: File, Export, Save As a (svg.)
Step 11: Materials
By your minerals at your local home mantle store
I got my materials at Home Depot
Wood: https://www.homedepot.com/p/Hardboard-Tempered
Wood glue: https://www.homedepot.com0/100672167
Acrylic Paint: https://www.walmart.com/browse/arts-crafts-sewing/acrylic-paints
Step 12:
Step 13: Open Your File in Adobe Illustrator
You will need to covert your file so the laser cutter can use it.
Step 14: Converting You File to Something the Laser Cutter Can Read.
- Open up Adobe Illustrator.
- Open your SVG file
- Choose your selection tool in your toolbox
- Click on the line of one of your shapes
- Right-click then press “release clipping mask”
- Select on the same line Right click and ungroup
- Then select the background and delete
- Click “File”, “save as”, Convert it to a “Adobe Illustrator (ai)”
- Save
Step 15: Cut You Box in the Laser Cutter
Step 16: Glue
To make the glowing prosses faster and pain-free lay your box out flat like the image above and put glue in a straight line. Then assemble the box. You might need an extra pair of hand for this.
Let it sit for 24 hours at least
Step 17: Clamp
Clamp your box.
You can either use 3 clamps or tape
Clamps: You will need 3 claps
Place one clamp on your top and bottom securing them together
The other one goes on the side that is shaped like a square
The last one goes on the rectangle shape side.
Tape: It is the same thing with the clamps just do not be afraid to use a lot of tapes. When you think you are done with the tape add one long piece around all the sides. And one long piece to connect the top and bottom
Step 18: Sand
Sand the aces glue off to make the box smooth
use an 80-100 grade sandpaper. Sand lightly with quick motions.
Repeat as many times as necessary.
Step 19: Optional: Paint
Originally I did not want to paint my box but after looking at some images of design I decided to paint mine.
Step 20: Plan for Paint
Look up some images as your inspiration on how you would like your box to resemble.
Step 21: Tape It Off
Tape off your design if you are doing multiple colors
Step 22: Experiment With Your Colors
Take a scrap wood and experiment with what your finish product would look like. Paint, sand ect.
Step 23: Paint
Step 24: Add a Clear Cote
This will protect and add a gloss finish.
This will be spray paint
Step 25: Spray Paint
Shake well before using it is very important to shake
Don’t spray too close or far
Test the nozzle (Sometimes nozzles sputter a bit and need a spray or two to get going).
Spray about 6 to 8 inches away from your surface and do a thin, even coat while moving the can in a sweeping motion from side to side.
Several thin coats will look much better than one thick coat and will help prevent drips.
Let it dry thoroughly if a second coat is needed, you can repeat the process
Once you're satisfied with the coverage, let it dry for at least 24 hours.
