Introduction: Tim's Aluminium Label Maker
This Instructable is how I made some one inch high Aluminium labels from Aluminium drink cans.
The process requires a 3D Printer to print the Die used to make the set of alphanumeric characters I designed.
- There is a 3D printed press.
- A set of 3D printed rollers.
- Also a 3D Printed pair of shaped pliers, for crimping the borders.
The end result is a little rough, but I think it give it a classic look.
- I think it gives more of a polished cast aluminium look.
Once the tools have been made there is not much to the Instruction, it may be best understood in the video.
As I have mentioned, a 3D printer is required to make the tools.
- A full list of all the required parts are attached.
- My printer has a 0.4mm diameter nozzle.
- To save some time, I have the layer thickness set to 0.3mm.
- Shell thickness is 1.8mm.
- Fill density is 20%.
Being able to hold the tools in a vice is a must.
Several screws are required.
- M3 x 10mm Flat End Self-Tapping screws for fixing the tools together.
- M1.7 x 6mm Flat End Self-Tapping screws for fixing the labels to whatever.
Eight 3x10x4 Roller Bearings are required.
Some old Aluminium Drink Cans.
Small Flame Torch to Anneal the Aluminium.
A Pair of strong Scissors.
Every day items like pencil, ruler and Pan Scrubber.
Frame_Fixed.stl
Frame_Pivot.stl
Roller_Bottom.stl
Roller_Top.stl
Pliers_Top.stl
Pliers_Bottom.stl
Arm.stl
Base_Body.stl
Base_Side.stl
Roller.stl
Washer.stl
Die_Bottom_A.stl
Die_Top_A.stl
Die_Bottom_B.stl
Die_Top_B.stl
Die_Top_C.stl
Die_Bottom_C.stl
Die_Bottom_D.stl
Die_Top_D.stl
Die_Bottom_E.stl
Die_Top_E.stl
Die_Bottom_F.stl
Die_Top_F.stl
Die_Bottom_G.stl
Die_Top_G.stl
Die_Bottom_H.stl
Die_Top_H.stl
Die_Top_I.stl
Die_Bottom_I.stl
Die_Bottom_J.stl
Die_Top_J.stl
Die_Top_K.stl
Die_Bottom_K.stl
Die_Top_L.stl
Die_Bottom_L.stl
Die_Bottom_M.stl
Die_Top_M.stl
Die_Top_N.stl
Die_Bottom_N.stl
Die_Bottom_O.stl
Die_Top_O.stl
Die_Top_P.stl
Die_Bottom_P.stl
Die_Top_Q.stl
Die_Bottom_Q.stl
Die_Top_R.stl
Die_Bottom_R.stl
Die_Top_S.stl
Die_Bottom_S.stl
Die_Top_T.stl
Die_Bottom_T.stl
Die_Top_U.stl
Die_Bottom_U.stl
Die_Top_V.stl
Die_Bottom_V.stl
Die_Bottom_W.stl
Die_Top_W.stl
Die_Top_X.stl
Die_Bottom_X.stl
Die_Top_Y.stl
Die_Bottom_Y.stl
Die_Top_Z.stl
Die_Bottom_Z.stl
Die_Top_0.stl
Die_Bottom_0.stl
Die_Bottom_1.stl
Die_Top_1.stl
Die_Bottom_2.stl
Die_Top_2.stl
Die_Bottom_3.stl
Die_Top_3.stl
Die_Bottom_4.stl
Die_Top_4.stl
Die_Bottom_5.stl
Die_Top_5.stl
Die_Bottom_6.stl
Die_Top_6.stl
Die_Bottom_7.stl
Die_Top_7.stl
Die_Bottom_8.stl
Die_Top_8.stl
Die_Bottom_9.stl
Die_Top_9.stl
Die_Bottom_End.stl
Die_Top_End.stl
Step 1: The Press
Hopefully the Brake-Out Sketch shows how the Press goes together.
Printed Parts:
- Base_Body.stl
- Base_Side.stl (Printed as is)
- Base_Side.stl (Printed Mirror Image)
- Roller.stl
- Washer.stl (Four Required)
- Arm.stl
Notes!
There is only an STL for one side, the other side needs to be a Mirror Print.
There are washers on the inside of each bearings.
- I found it easier to place the roller in position, then fit the washer, then the bearing and finally the screw.
- I did the same as a above for the Arm after connecting the two sides.
Screws used.
- Ten M3 x 10mm long flat ended self tapping screws.
Step 2: Rollers
Again hopefully you can see how it goes together from the Brake-Out sketch.
Note!
The two screws that the top piece pivots on, should be unscrewed a little, to enable the sides to spring past the screws that hold the lower roller.
Step 3: Pliers/Crimp
Just one screw holds these together.
These are used to re-shape the top and bottom of the labels.
Step 4: Aluminium Strips
The aluminium Strips are cut from Old Drink Cans.
- Cut off the Top and Bottom shaped part of the Can.
- Cut the middle part along its length.
- Flatten the centre piece and and cut into One Inch Strips (25mm)
The Aluminium from Old Drink Cans has been work hardened through the process of making them.
- They need to be annealed to soften the Aluminium.
- If the Aluminium is not soft the Die will not be able to shape the Aluminium.
To Soften the Aluminium it needs heating with a flame torch.
- To anneal Aluminium requires a special heat process, but I do it a simple way and it's good enough for this.
- From the painted side, use the flame torch to heat the Aluminium.
- Don't rush it with a too hotter flame, you will just melt the Aluminium.
- Keep heating it until it turns a golden brown.
- As one area turns golden brown, move along the strip to another area.
- Once it all has turned golden brown your done.
- Let it cool on its own.
You may want to hold the strip with some tool so you don't burn yourself.
Step 5: Die
Die are used to create the characters in the Aluminium Strip.
- The Aluminium Strip is placed between the two parts of the Die.
- Then the Die is placed in the Press to form the Character required.
It is best to hold the Press in a Vice, it will make it easier to use.
Step 6: Top/Bottom Ridge
After the Characters have been formed, use the Pliers to re-form the top and bottom of the label.
Step 7: Roll/Flatten
At this point the label may be a little twisted/curved.
- Placing it in the rollers and carefully running it back and forth, will reinforce the shape, to make it flat.
Step 8: Drill and Trim
Next step is to drill the mounting holes and trim the outer edges.
- Once you have it on a flat surface, you can use a rough cleaning pad to enhance the characters by removing the staining from the annealing process from the top surface.
![Tim's Piezoelectric Crystal Experiment [Noise Maker]](https://content.instructables.com/FAB/RCS8/MG8A0APJ/FABRCS8MG8A0APJ.png?auto=webp&crop=1%3A1&frame=1&width=130)
