Introduction: Tinee9: Arduino Controlled ESC
4 Years ago I made my own drone for a cost of $300 back when the first commercial drone was about $1500. The Arducopter controller controlled the motor ESC, I used the DJI DIY frame, and bought a 720MHZ remote control. Here is a modified KIT of what I built 4 years ago. KIT Now that I have bit more experience in electronics aerospace engineering, I want to build my own PCBA controller to control the drone.
I will be using Arduino for my platform. For today, I will demonstrate that we can control an ESC with and arduino nano.
Difficulty: Moderate
Knowledge: Need to know soldering, Need to know basic power connections of a drone.
Reminder Tinee9.com has other Tutorials regarding Arduino and also talks about common electronics such as Drones. I talk about how they are used and how the sensors work on Drones used by companies or research and development teams.
Step 1: Materials
I didn't want to choose the solder, solder Iron, PC, and USB Cable but you can get the rest of the Items from this link KIT
Materials: ESC
Motor
Battery that will run the motor
Solder
Solder Iron
Arduino Nano
Bread Board
Jumper Wire
PC
USB Cable
Arduino IDE
Step 2: Basic Assembly
Step 1: Solder your Motor to the ESC controller.
Step 2: Attach your Arduino Nano to a bread board.
Step 3: Attach your Battery - to the ESC Black Wire.
Step 4: Attach your ESC Black to the Arduino GND Pin.
Step 5: Attach your ESC White wire to Arduino D9 Pin.
Step 6: Attach Arduino Nano to PC with USB Cable.
Step 3: Code
Step 7: Program Arduino Nano with this Code in Arduino IDE.
What the code is doing is initializing ESC and then it ramps up faster every 0.25 seconds till a hardcoded set point then turns off. Then repeats. Basically this code is allowing you to see how a motor is commanded by an ESC. Also the code is the basic building block for commanding 4 ESCs at the same time when you develop the rest of the code to fly a fixed wing or quadcopter.
Code:
#include <Servo.h>;
Servo esc;
int Pin = 0;
int x = 0;
void setup() {
esc.attach(9); }
void loop() {
int throttle = analogRead(Pin);
throttle = map(throttle, 0, 1023, 0, 179);
for(x = 0; x < 175; x++){
esc.write(x); delay (250); }
esc.write(0);
delay(10000); }
Step 4: Connect and Run
Step 8: Attach your ESC Red wire to Battery +.
Step 9: Enjoy your Arduino Nano commanding the ESC with PWM commands.
