Introduction: Tinfoil Emergency Battery Device Fix
Have you ever had a problem when one of your devices, a flashlight, radio, remote has a problem where one of the battery contacts breaks or the spring that holds the battery tight is off center or breaks off? Or the contact is loose so the battery doesn't fit tightly?
You can order some clip replacements and hope they fit, but what if you need the device NOW!!
Well this is so SIMPLE yet most people haven't thought of it!
tin foil.
Step 1:
Very simple. Ball up a small bit of tin foil and put it in between the battery and the loose contact. Just enough to keep it snug. That's it!!! It will work like new.
