Introduction: Tinker CAD Neopixel Clock
Hi guys! Here is how you can make a cool neopixel clock. Its very easy and cool, just follow the steps to make them.
Step 1: Coding
It is very easy coding just copy paste the below code.
Code:
#include "Adafruit_NeoPixel.h"
#define NEOPIXEL_MINUTE_PIN 2
#define NEOPIXEL_HOUR_PIN 3
#define AM_PM_PIN1 4
#define AM_PM_PIN0 5
// Parameter 1 = number of pixels in strip // Parameter 2 = pin number (most are valid) // Parameter 3 = pixel type flags, add together as needed: // NEO_KHZ800 800 KHz bitstream (most NeoPixel products w/WS2812 LEDs) // NEO_KHZ400 400 KHz (classic 'v1' (not v2) FLORA pixels, WS2811 drivers) // NEO_GRB Pixels are wired for GRB bitstream (most NeoPixel products) // NEO_RGB Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2) Adafruit_NeoPixel stripMinute = Adafruit_NeoPixel(24, NEOPIXEL_MINUTE_PIN, NEO_GRB + NEO_KHZ800); Adafruit_NeoPixel stripHour = Adafruit_NeoPixel(12, NEOPIXEL_HOUR_PIN, NEO_GRB + NEO_KHZ800);
String ssid = "Simulator Wifi"; // SSID to connect to String password = ""; // Our virtual wifi has no password (so dont do your banking stuff on this network) String host = "nist.time.gov"; // Open Weather Map API const int httpPort = 80; String uri = "/actualtime.cgi?lzbc=1462431600000000";
int second = 60; int minute = 55; int hour = 15;
int setupESP8266(void) { // Start our ESP8266 Serial Communication Serial.begin(115200); // Serial connection over USB to computer Serial.println("AT"); // Serial connection on Tx / Rx port to ESP8266 delay(10); // Wait a little for the ESP to respond if (!Serial.find("OK")) return 1; // Connect to 123D Circuits Simulator Wifi Serial.println("AT+CWJAP=\"" + ssid + "\",\"" + password + "\""); delay(10); // Wait a little for the ESP to respond if (!Serial.find("OK")) return 2; // Open TCP connection to the host: Serial.println("AT+CIPSTART=\"TCP\",\"" + host + "\"," + httpPort); delay(50); // Wait a little for the ESP to respond if (!Serial.find("OK")) return 3; return 0; }
long getTimeESP8266(void) { // Construct our HTTP call String httpPacket = "GET " + uri + " HTTP/1.1\r\nHost: " + host + "\r\n\r\n"; int length = httpPacket.length(); // Send our message length Serial.print("AT+CIPSEND="); Serial.println(length); delay(10); // Wait a little for the ESP to respond if (!Serial.find(">")) return -1;
// Send our http request Serial.print(httpPacket); delay(10); // Wait a little for the ESP to respond if (!Serial.find("SEND OK\r\n")) return -2; while(!Serial.available()) delay(5); // wait until we receive the response from the server
String outputString = ""; if (Serial.find("\r\n\r\n")) { // search for a blank line which defines the end of the http header delay(5); unsigned int i = 0; //timeout counter while (!Serial.find("delay=\"")){ delay(1); } // find the part we are interested in. while (i<60000) { // 1 minute timeout checker if(Serial.available()) { char c = Serial.read(); if(c=='"') break; // break out of our loop because we got all we need outputString += c; // append to our output string i=0; // reset our timeout counter } i++; delay(1); } } outputString.remove(outputString.length() - 6); return outputString.toInt(); }
int sychronizeTime(void) { drawHourHand(-1); long now = getTimeESP8266(); if (now >= 0) { second = now % 60; now /= 60; minute = now % 60; now /= 60; hour = now % 24; } }
void setPixelColor(Adafruit_NeoPixel& strip, int index, unsigned char red, unsigned char green, unsigned char blue, int brightness = 256) { strip.setPixelColor( index, (((int)red) * brightness) >> 8, (((int)green) * brightness) >> 8, (((int)blue) * brightness) >> 8 ); }
#define BRIGHTNESS 256
void drawMinuteHand(void) { stripMinute.clear(); int value = minute * 2; int index; int i; for (i = 0, index = 0; i < 120; i += 5, ++index) { int dist = (value > i) ? value - i : i - value; if (dist > 60) dist = 120 - dist; setPixelColor(stripMinute, index, dist < 10 ? 2 * (10 - dist) * (10 - dist) : 0, 0, 0, BRIGHTNESS); } stripMinute.show(); }
void drawHourHand(int sweep) { stripHour.clear(); int hour12 = (hour > 11) ? hour - 12 : hour; if (sweep < 0) { for (int i = 0; i < 12; ++i) { // Display blue to show internet access setPixelColor(stripHour, i, 0, 64, 128, BRIGHTNESS); } } else { if (hour12 == sweep) { setPixelColor(stripHour, sweep, 0, 128, 255, BRIGHTNESS); setPixelColor(stripHour, sweep + 1, 0, 64, 128, BRIGHTNESS); } else if (hour12 == sweep + 1) { setPixelColor(stripHour, sweep, 0, 32, 64, BRIGHTNESS); setPixelColor(stripHour, sweep + 1, 0, 128, 255, BRIGHTNESS); } else { setPixelColor(stripHour, sweep, 0, 32, 64, BRIGHTNESS); setPixelColor(stripHour, sweep + 1, 0, 64, 128, BRIGHTNESS); setPixelColor(stripHour, hour12, 0, 128, 255, BRIGHTNESS); } } stripHour.show(); }
void updateClock(void) { // This gets called 24 times per second. static int count = 0; if (++count == 24) { count = 0; // Update the time display if (++second >= 60) { // Update the minute if (++minute >= 60) { minute = 0; if (++hour >= 24) { hour = 0; } } second = 0; // Draw the minute hand drawMinuteHand(); } }
if (!(count & 3)) { drawHourHand(count >> 1); // Update AM/PM digitalWrite(AM_PM_PIN0, LOW); digitalWrite(AM_PM_PIN1, (hour >= 12) ? HIGH : LOW); } }
ISR(TIMER2_COMPA_vect) { static unsigned char count = 0; // This interrupt is being called 125 times per second. // Trigger a function call exactly 24 times per second using math: count += 24; if (count >= 125) { count -= 125; updateClock(); } }
void setup() { digitalWrite(AM_PM_PIN0, HIGH); pinMode(AM_PM_PIN0, OUTPUT); digitalWrite(AM_PM_PIN1, HIGH); pinMode(AM_PM_PIN1, OUTPUT); stripMinute.begin(); stripHour.begin();
stripMinute.show(); // Initialize all pixels to 'off' stripHour.show(); // Initialize all pixels to 'off' setupESP8266(); sychronizeTime(); drawMinuteHand();
// Set up timer2 to interrupt 125 times per second TCCR2B = 0x00; //Disbale Timer2 while we set it up TCNT2 = 0; //Reset Timer Count to 0 out of 255 OCR2A = 125; //Counter compare value TIFR2 = 0x00; //Timer2 INT Flag Reg: Clear Timer Overflow Flag TIMSK2 = 0x02; //Timer2 INT Reg: Timer2 compare A interrupt TCCR2A = 0x02; //Timer2 Control Reg A: CTC TCCR2B = 0x07; //Timer2 Control Reg B: Timer Prescaler set to 1024 }
void loop() { static int lastSecond = 0; if (second == 45 && lastSecond == 44) { // Once per minute (at 45 seconds after the minute), sychronize the time sychronizeTime(); } lastSecond = second; delay(100); }
