Introduction: TinkerCAD Design: DIY Dice
Hi. All. In this particular Instructable. I am going to share with you how to create a 3D Model of a Rolling Dice.
Step 1: Step 1:
Drag a Cube from the Components Panel and place it in the middle of the screen
Step 2: Step 2:
Make the Radius of the Cube set to 3.0
Step 3: Step 3:
Go to the Components Panel and Choose number 1 and place it on the screen
Step 4: Step 4
Rotate the number 1 to match to one side of the dice cube.
Step 5: Step 5:
Pull the number to make sure it stands on the plane
Step 6: Step 6:
Convert the Entire number Block to Hole
Step 7: Step 7:
Now Select both the Cube as well as the Number and Align accordingly to the face of the cube.
Step 8: Step 8:
Group it. Once Grouped you will be able to see the above image.
Step 9: Step 9:
Repeat the same steps by adding numbers 2,3,4,5 & 6 and group it together to obtain the final Image design.
