Introduction: TinkerCAD Figures
I made a figure template in TinkerCAD because I wanted to have some fun! They are 3d printed and can be colored and customized. This is only a template.
You will need to go to https://www.tinkercad.com to get started and a 3d printer!
Step 1: Create the Head
Make a 20mm by 20mm by 20mm cylinder and set sides to 48, bevel to 25, and set segments to 8. You can use any color.
Step 2: Limbs
Place a rectangle and set its length by width to 20mm by 17.5mm. Make sure to set it's height to 35mm. Additionally, set the radius to 1, and set steps to 8.
Step 3: Torso
Get another rectangle and set its dimensions to 20mm, 35mm, and set its height to 35mm too.
Step 4: Exporting
group all of the objects together and export them as an STL. Then slice them and print! (I used Prusa Slicer!.) Then import the file into Prusa Slicer, then slice the STL.
Step 5: Glue
Lastly, use glue to glue all the pieces together. Now you have a template of a figure! You can customize it in tinkerCAD to put your own twist on it! Additionally, you can also paint it to bring it to life!
