Introduction: Tinkercad Design Contest Noob
hi, if you want to make a roblox noob in tinkercad than you got the right instructable!
a computer
tinkercad
fingers
a brain
Step 1: Make the Body
get a box and make the length and height 40mm and the width 20mm
Step 2: Raise the Body 40 Off the Ground
do this by using the little cone
Step 3: Set the Radius to 1
Step 4: Copy and Paste the Body and Set It on the Ground, Make the Length and Width 20mm But the Height 40mm. This Will Be the Leg
Step 5: Align the Shapes to Be Flat in Width and on the Right
Step 6: Copy and Paste the Leg
Step 7: Group the Right Leg and the Body
do this by highlighting the shapes and hit group
Step 8: Align the Leg As Shown
Step 9: Un Group the Shapes, and Color It As Shown
Step 10: Copy and Paste a Leg Twice and Make Sure That There Is a 80mm Gap Difference Between and That They Are Even
Step 11: These Will Be the Arms, Group Them and Make Them Yellow
Step 12: Group the Body and Legs and Set It to Multicolor
Step 13: Group the Arms and Raise Them 40
Step 14: Align the Arms and Body to Be Centered and Flat
Step 15: Create the Head
make a 25mmx25mmx25mm cylinder with the sides bevel and segments to be maxed out. then raise it 80mm and align it it be centered and on the body
Step 16: Make the Eyes
each eye must be a 6mmx6mmx6mm spheres, and they are 15.5mm apart and 13mm off the ground
Step 17: Make the Mouth
the mouth is using the text block and typing capital V in the sans font and it has to be 2mm off the ground, 15.5mm in with and 3mm in length and 6mm in height.
Step 18: Group the Face and Move It Up to 84.8mm Off the Ground and Then Center It and Move It on the Head
Step 19: Enlarge the Noob Until It Is 113.6mm Tall and Is a Scaled Copy
do this by holding shift while extending the top
Step 20: Now You Have a Noob :>
Step 21: E N J O Y -Disconnecting...
Modify to your choosing!
