Introduction: Tinkercad Mini Table
I’m this instructable we will be making a mini table using Tinkercad. If you want to take the short way I’ll put the file down below.
Tinkercad Account (free)
3D Printer
Step 1: Get a Cube
Get a cube from the shapes menu and make it:
Length: 50mm
Width: 40mm
Height: 5mm
Step 2: Get Four Cubes and Fit Them to Specs
get four more cubes and make them:
Length: 7.5mm
Width: 7.5mm
Height: 20mm
Step 3: Grab 4 Hole Cubes
Get four hole cubes and size them down to:
Length: 8mm
Width: 8mm
Height: 7mm
Step 4: Put the Holes on Each Corner
Put one hole on each corner and try and line them up as best you can. After that, group the holes into the table piece by holding and dragging your mouse over just the holes and the table top.
Step 5: Export to Stl
Export to an stl file by hitting the export button.
Step 6: Print!
Go ahead and print!
Step 7: Push Table Legs Into Table Top
I use a hammer and lightly tapped, it in but you might be able to do it with your hands. This is what the finished project should look like. If you liked this instructable please consider following. Thank you.
