Introduction: Tiny House on Wheels
I started my new tiny house project.
Step 1: Cheap Tiny House on Wheels Build #1 - Building Trailer
This is my cheap tiny house on wheels building series. I'm re-uploading videos of my tiny house and making them more concentrated!
I'm building this tiny house trailer by myself. I got this old rusty flatbed tractor trailer and cut off all the unneeded parts, installing new bigger wheels, welding extra to have 8.2m in length. Removed all the rust from rims in electrolysis and painted them with a trailer. #tinyhouse #tinyhousetrailer #trailerbuild
Step 2: Cheap Tiny House on Wheels Build #2 - Building Floor Base
In this episode, I'm building a floor base for my cheap Tiny House on wheels. It`s made of wood framing (150x50mm or 2'x3'inch) and 10mm OSB sheets on the bottom, treated with bitumen. On top, we have 20mm OSB sheets.
#tinyhouse #tinyhouseonwheels #subfloorbuild
Step 3: Cheap Tiny House on Wheels Build #3 - Framing Walls and Installing OSB Sheating
In this video I will do my wall framing job, installing OSB cheating and ceiling beams. Walls up, then I move the tiny house outside.
#tinyhouse #tinyhouseonwheels #osbcheating #woodframing
Step 4: Cheap Tiny House on Wheels Build #4 - Installing Windows, Front Door Build, Painted OSB Facade
This time I'm installing windows with frames and double glass into the frame. I built a new front door, added trim for the tiny house and painted all the facade of OSB.
#tinyhouse #tinyhouseonwheels #osbsheating #windows #door
Step 5: Cheap Tiny House on Wheels Build #5 - Out of Garage and Building Roof
Building a cheap tiny house on wheels. Moving the house out of the garage and starting to build a roof. Roof rafters made out of 50x150 (2'x6'). I used rockwool for insulation with wind and water protective cover. After that a 1' spacers under the 1' ridges. Using metal trapezoid roof sheeting for roofing.
#tinyhouse #tinyhouseonwheels #roofing #metalroof #roofbuild
Step 6: Cheap Tiny House on Wheels Build #6 - Installing Electrical Wiring, Insulation and Vapor Barrier In
Building cheap tiny house. Installing electrical wiring, insulating with Rockwool and installing a vapor barrier.
#tinyhouse #tinyhouseonwheels #electricalwiring #insulation #vaporbarrier
Step 7: Cheap Tiny House on Wheels Build #7 - Installing Interior OSB, Window Trim, Laminate Flooring
Installing interior OSB boards, making window trim and installing laminate flooring to Tiny House. Also, I built a bathroom wall.
#tinyhouse #tinyhouseonwheels #osbinterior #osbhouse #laminateflooring
Step 8: Cheap Tiny House on Wheels Build #8 - Installing Wood Stove and Chimney
In this video, I moved my tiny house to another place. Installing the wood stove and chimney.
#tinyhouse #tinyhouseonwheels #movinghouser #woodstove #chimney
Step 9: Cheap Tiny House on Wheels Build #9 - Lacquer Interior to White
In this episode, I will mask up the floors and lacquer all the interior walls and ceiling to white.
#tinyhouse #tinyhouseonwheels #interior #lacquer
Step 10: Cheap Tiny House on Wheels Build #10 - Air Source Heat Pump Installation
In this video, I will fabricate a metal wall mount for an air source heat pump installation and installing the inside and outside units for my tiny house on wheels.
#tinyhouse #tinyhouseonwheels #heatpump
Step 11: Cheap Tiny House on Wheels Build #11 - House Moving Day
In this episode, I move the tiny house a little bit closer to piping connections and for a better location so I can connect sewerage pipe and clean water from the well. Tiny house moving day!
#tinyhouse #tinyhouseonwheels #housemove
Step 12: Cheap Tiny House on Wheels Build #12 - Building Front Door Wooden Stairs
Building simple wooden front door stairs for my tiny house on wheels. This stair is finished with wood oil.
#tinyhouse #stairs #woodenstairs #woodwork.
Step 13: Cheap Tiny House on Wheels Build #13 - Installing DIY LED Lighting Panel for Loft Ceiling
Building and installing an DIY LED lighting panel for my tiny house loft ceiling.
#tinyhouse #LEDpanel #lightingpanel #woodwork
