Tiny Inclinometer
Intro: Tiny Inclinometer
Today we will be building an Inclinometer using 4 of our boards that will effectively demonstrate the basic functionality of the 7 segment and accelerometer shields. This fun little demo will tell us the angle of the board in respect to gravity. Now that you know whats up, lets get started!
STEP 1: Setup
To kick things off, you will need the boards and the software. in order for the software to work properly, we need to add two libraries for anyone who does not wish to use the Codebender example. For any questions about installing/downloading libraries, check the link here. The proper drivers must also be installed to detect the COM ports. These drivers must be installed before downloading any codes from the codebender plugin. The drivers needed can be found here.
Materials
- TinyDuino Processor : link
- TinyShield 7 Segment Display: link
- TinyShield Accelerometer: link
- TinyShield USB: link
- 3.3 or 5V power source
A TinyDuino Processor using a coin cell battery would be sufficient for this project. In this example a 3.3V battery was used with a JST SH 2 pin male connector.
STEP 2: Assembly
Now that we are all squared away with the materials and downloads, lets move on to the hardest part: the assembly. Grab your four boards and get ready for some serious instructions...Ready? Stack the boards together and plug in the USB cord. Due to the amount of difficulty the assembly requires, it would be completely understandable if this step took anywhere from 10 to 15 minuets.
STEP 3: Programming the Boards
Ok, we got through the assembly, time to move on to the actual code we will be uploading to the TinyDuino. First things first, we need to include Wire.h, BMA250.h, and Tiny7Seg.h. The code below can be downloaded to your computer or directly uploaded to your TinyDuino.
STEP 4: Let the Magic Happen!
We got the board assembled and programmed, so lets watch it work! If you have the TinyDuino with the coin cell battery or a 3.3V to 5V battery with a JST SH 2 pin male connector, the Inclinometer will be able to run on its own. If you don't have any batteries hooked up, that's fine too! It will work just fine while plugged in with the USB, you will just have a limited range of mobility. With all that said and done, we now have a fully operational Inclinometer!
2 Comments
robotobor 9 years ago
This would be very helpful to non-carpenters like me measure angles and make better cuts.
rusty0101 9 years ago
A variation on this might be to use one of the led ring boards (as in the tinyduino compass) and build a 'bubble' level with it that lights up all of the leds if its placed on a level surface (ring up) or lights up the 'high' side if the surface is not level. If it's placed on it's side, all but one (or two or three) of the high side led's are on, with the vertical point led being off, or some pattern letting you know what is the plumb point.
